How to define the rotation of a planet in retograde orbit?
  • Context: Undergrad
  • Thread starter Thread starter Alltimegreat1
    Orbit Planet Rotation
The discussion revolves around defining the rotation of a planet in retrograde orbit, exploring the relationship between its rotation direction and its orbital motion. Participants examine the implications of different reference frames and perspectives, as well as the definitions of prograde and retrograde rotation in relation to various celestial bodies.
  • Some participants suggest that if a planet orbits anticlockwise around a central object that rotates clockwise, it would also rotate clockwise to be considered in retrograde.
  • Others argue that the definition of retrograde rotation depends on the observer's perspective, particularly whether they are viewing from above the north or south pole.
  • One participant proposes that if the axis of rotation of the planet is aligned with that of the central object, the perspective from which one views the motion is crucial.
  • It is noted that a planet's rotation could be considered retrograde in relation to the rotation of the sun, but prograde in relation to its own orbital direction around the sun.
  • Some participants express confusion regarding how to define prograde and retrograde rotation, especially when considering axial tilt and reference frames.
  • A hypothetical scenario is presented where Earth retains its rotational direction while orbiting in the opposite direction, leading to a discussion about the implications for defining its rotation as prograde or retrograde.
  • References to Uranus and its moons are made to illustrate the complexities of retrograde and prograde motion, emphasizing the relativity of the definitions based on the observer's position.
Participants do not reach a consensus on the definitions of retrograde and prograde rotation, with multiple competing views and uncertainties remaining throughout the discussion.
The discussion highlights limitations in defining rotation based on reference frames, the potential confusion introduced by axial tilt, and the need for clarity in the definitions of prograde and retrograde motion.
Alltimegreat1
If a planet is in retrograde orbit, what direction would it rotate to also have retrograde rotation?
Astronomy news on Phys.org
If it is orbiting anticlockwise around an object which is rotating clockwise, then assuming by retrograde rotation in relation to the motion around that central object, I would suggest it too would rotate clockwise.
Actually this is a bit tricky question because it depends on the observer, if you are above the "north" pole looking below, or below the south pole looking above, but I suppose it would the reverse or negative of whatever you consider prograde rotation.
Assuming the OP might be assuming the axis of rotation of the planet is in the same plane as that of the central object? And that the perspective is from a relative viewpoint to both.
The sun rotates counter-clockwise as viewed from above looking down at its north pole. Let's assume one of its planets orbits the sun clockwise (retrograde) and also rotates clockwise. Is this planet's rotation prograde or retrograde?
I would say its rotation would be retrograde in relation to the rotation of the sun, but prograde in relation to its own orbital rotation of the sun
Actually let's compare with the Earth, from above north pole it rotates counter clock wise around itself and around the sun. So the retrograde is the opposite of both.
So yes that is retrograde.
So does that mean that retrograde/prograde rotation refers to the object's rotation compared to its own orbital direction, regardless of whether that orbit is retrograde or prograde?
See it depends on several things, is Earth your reference frame? How do you define the north pole of a planet? so on...
Also this notion of prograde or retrograde around itself gets really confusing if the planet axis inclination goes to 90 degrees compared with everything else, but again retrograde is going to be the negative of whatever you have considered prograde.
I could be wrong, but my common sense approach is you have to define with what you are relating the observation. You could be retrograde to the spinning rotation of an object, but prograde to your own orbital path around that object, irrespective of the central objects spin?
Yes it is a bit confusing, but we should try to get to the bottom of this. To make things easier, let's assume all objects in the solar system have no axial tilt. If our Earth, which has both prograde orbit and rotation, suddenly started orbiting in the opposite direction but retained its current rotational direction, it would have a retrograde orbit but a rotation that is prograde compared to the sun but retrograde compared to its own orbit.
Alltimegreat1 said:
https://en.m.wikipedia.org/wiki/Retrograde_and_prograde_motion The part about the Uranus moons explains it I think. Uranus had retrograde rotation, and its moons rotate the same way Uranus does, meaning the moons have prograde rotation compared to Uranus and retrograde rotation compared to the sun.
Again it brings you back to relativity in the sense of where you are looking and from what you are measuring against.
  • · Replies 41 ·
  • · Replies 83 ·
  • · Replies 19 ·
  • · Replies 22 ·
