How to Derive the Phase Expression from Modulation Equations?
  • Context: Graduate
  • Thread starter Thread starter JasonMech
    Modulation Phase
The discussion revolves around deriving a phase expression from given modulation equations in the context of mathematical analysis. Participants explore various mathematical manipulations and approaches to isolate the phase variable, δ, in terms of another variable, φ.
  • Mathematical reasoning, Technical explanation, Debate/contested
  • One participant presents modulation equations and seeks help to derive an expression for the phase δ.
  • Another suggests expanding trigonometric identities to facilitate the derivation.
  • A participant describes their attempts to manipulate the equations using trigonometric identities and expresses difficulty isolating δ.
  • Another participant shares their approach of converting all terms into tangent functions and arrives at a complex equation.
  • There is mention of using cross multiplication to simplify the equations, but participants express uncertainty about the correctness of their results.
  • One participant highlights a discrepancy in the derived expressions for δ, questioning the validity of the approaches taken by others.
  • Another participant clarifies a previous comment about multiplication, indicating a misunderstanding in terminology.
Participants generally do not reach a consensus on the correct method to derive the phase expression, with multiple competing views and approaches presented. The discussion remains unresolved regarding the correct expression for δ.
Participants express various assumptions and conditions in their manipulations, and there are unresolved steps in the mathematical processes discussed. The complexity of the equations and the different approaches contribute to the uncertainty in reaching a definitive expression for δ.
JasonMech
Hi guys,
I need some help. I have the following modulation equations:
[tex]\Re:-\zeta a+\lambda a\cos 2\delta-\eta \cos (\delta+\phi)=0[/tex]
and
[tex]\Im:\omega a+\lambda a\sin 2\delta-\eta \sin (\delta+\phi)=0[/tex]
which, with proper manipulation (i.e. by squaring and adding and/or diving them with each other) should give me an expression for the phase:
[tex]\delta=\arctan \frac{\left(\lambda-\omega\right)\sin\phi-\zeta\cos\phi}{\left(\lambda+\omega\right)\cos\phi-\zeta\sin\phi}[/tex]
I just can't see the link... That is, I cannot reach this expression! By dividing the imaginary part with the real part of the modulation eqns:
[tex]\tan \left(\delta+\phi\right)=\frac{\omega+\lambda\sin 2\delta}{-\zeta+\lambda\cos 2\delta}.[/tex]
Then, we should obtain an expression for the phase $\delta$ in terms of $\phi$ and through some manipulation we should arrive at [tex]\delta=\arctan \left[...\right][/tex]
Can you solve this challenge? (This is NOT classical homework although it might seem so!)
(Thread moved from ME to Calculus & Analysis to get better math views...)
Why don't you expand?
[itex]\sin 2x=2\sin x\cos x[/itex] and so forth and you have to write sin and cos in terms of tan.
Hi hunt_mat,
I have already, along other approaches, done that. With your proposal, i.e. invoking the relations:
[tex]\sin 2\delta=2\sin\delta\cos\delta,\quad \cos 2\delta=1-2\sin^2\delta[/tex]
and
[tex]\tan\delta=\frac{\sin\delta}{\cos\delta},\quad \tan(\delta+\phi)=\frac{\tan\delta+\tan\phi}{1-\tan\delta\tan\phi},[/tex]
and substituting these into:
one obtains:
[tex]\tan\delta+\tan\phi=\frac{\omega+2\lambda \tan \delta}{-\zeta+\lambda\left(1-2\frac{\tan^2\delta}{\cos^2\delta}\right)}\left(1-\tan\delta\tan\phi\right)[/tex]
This expression can be isolated wrt. \phi with some additional algebraic manipulations:
[tex]\phi=\arctan\left\{\frac{\omega+2\lambda \tan \delta -\left[-\zeta+\lambda\left(1-2\frac{\tan ^2\delta}{\cos^2\delta}\right)\tan \delta\right]}{\left(\omega+2\lambda \tan \delta\right)\tan \delta-\zeta+\lambda\left(1-2\frac{\tan ^2\delta}{\cos^2\delta}\right)}\right\}.[/tex]
However, I am interested in an expression for the variable \delta in terms of \phi.
I have difficulties isolating \delta in the aforementioned eqn. If you have some ideas that would be highly appreciated.
First I did what you did and isolate the [itex]a[/itex] and the [itex]\eta[/itex] and divide through by each other to obtain:
[tex] \tan \left(\delta+\phi\right)=\frac{\omega+\lambda\sin 2\delta}{-\zeta+\lambda\cos 2\delta}[/tex]
Then I turned everything I could see into tan, so
[tex] \sin 2\delta =\frac{2\tan\delta}{1+\tan^{2}\delta},\quad\cos 2\delta =\frac{1-\tan^{2}\delta}{1+\tan^{2}\delta}[/tex]
doing this lead me to this equation:
[tex] \frac{\omega (1+\tan^{2}\delta)+2\lambda\tan\delta}{\lambda -\zeta -(\lambda +\zeta)\tan^{2}\delta}=\frac{\tan\delta +\tan\phi}{1-\tan\delta\tan\phi}[/tex]
From here, cos multiply, rearrange and cross your fingers.
Have you gotten from:
[tex]\frac{\omega (1+\tan^{2}\delta)+2\lambda\tan\delta}{\lambda -\zeta -(\lambda +\zeta)\tan^{2}\delta}=\frac{\tan\delta +\tan\phi}{1-\tan\delta\tan\phi}[/tex]
to:
I didnt think about using the trig id:
[tex]\sin 2\delta =\frac{2\tan\delta}{1+\tan^{2}\delta},\quad\cos 2\delta =\frac{1-\tan^{2}\delta}{1+\tan^{2}\delta}[/tex]
before, so that's a nice comment. I don't know whether you with "cos multiply" meant both in the numerator and denominator or only numerator and whether it should be only on the right hand side of the eqn or on both sides of the eqn. All approaches are valid I guess. I tried all of them of which the firstmentioned writes:
[tex]\frac{\sin \delta +\cos \delta \tan \phi}{\cos \delta -\sin \delta \tan \phi}=\frac{\omega \left(\cos \delta +\frac{\sin ^2\delta}{\cos \delta}\right)+2\lambda \sin \delta}{\left(\lambda-\zeta\right)\cos \delta -\left(\zeta+\lambda\right)\frac{\sin ^2\delta}{\cos \delta}}[/tex]
which is not, to me, near the sought solution:
Solving:
wrt. $\delta$ and multiplying with $\cos \phi$ (note that this approach is different than the one you proposed; here I solve and subsequently multiply with $\cos \phi$ and not $\cos \delta$) in Maple yields:
[tex]\delta=\arctan \left\{\frac{\left(\zeta+\lambda\right)\sin \phi +\omega \cos \phi}{-\left(\zeta+\lambda\right)\cos \phi+\omega \sin \phi}\right\}[/tex]
which differs with change in sign and (more importantly) the variables are attached to different trigonometric functions. Thus, I am very curious if you got the correct result? And of course, I am dying to get a hint... :-)
It was a typo, cos multiply was meant to be cross multiply. That is as far as I got as I only wanted to get a feel of the problem to give you a hint of how to solve your problem.
My idea was to get an equation for [itex]\tan\delta[/itex] first.
