How to determine the x values where a function is continuous
  • Thread starter Thread starter TheRedDevil18
    Continuous Function
To determine the x values where the function f(x) = sqrt(9-x^2)/(x^2-1) is continuous, it is essential to identify points of discontinuity, specifically at x = 1 and x = -1, where the function is undefined. The function is continuous elsewhere, as it is a composition of continuous functions. Analyzing the limits near the discontinuities reveals that the limit approaches +∞ from the right and -∞ from the left at x = 1, indicating an infinite discontinuity, while the opposite occurs at x = -1. Additionally, the square root imposes a restriction, meaning the function is continuous on the intervals [-3, -1) and (1, 3]. Understanding these characteristics is crucial for analyzing the function's continuity.
TheRedDevil18
How would I find the x values for which a function is continuous ?, and how to tell whether it is a removable discontinuity, a jump discontinuity, or an infinite discontinuity ?
Suppose the function is sqrt(9-x^2)/x^2-1
\frac{\sqrt{9-x^2}}{x^2-1}=\frac{\sqrt{9-x^2}}{(x-1)(x+1)}. So your function is not defined on the points 1 and -1, but it is continuous on the other points as a composition of basic continuous functions. To study the behavior of the function near the singularities, you calculate the limits, you will find \lim_{x\rightarrow 1} \frac{\sqrt{9-x^2}}{x^2-1}=+ \infty from the right and -\infty from the left. The opposite thing happens for -1.
Wouldn't the numerator also have a restriction ?, the square root can't be negative. So would it be correct in saying that the graph is continuous on the intervals [-3,-1) U [3,1) ?
f is continuous WHEREVER it is DEFINED (i.e, has a function value).
Interval notation goes left to right, so this would be written as [-3, -1) U (1, 3[/color]].
Technically, ##\lim_{x\to 1} \frac{\sqrt{9-x^2}}{x^2-1} ## does not exist, since the left and right limits are different (which is what you said). The notation that is often used is
##\lim_{x \to 1^+} \frac{\sqrt{9-x^2}}{x^2-1} = \infty## and ##\lim_{x \to 1^-} \frac{\sqrt{9-x^2}}{x^2-1} = -\infty##.
The function is perfectly continuous at (-1,1) as well.
  • · Replies 17 ·
