How to Display Days in Order for My Clock: Java Homework Solution
9 replies · 4K views · last reply
Albert12
How to display days in order for my clock :
Code:
Thursday, 12:00 pm
Thursday, 2:30 pm
Friday, 12:15 am
Friday, 12:15 am
Thursday, 2:30 pm
Saturday, 2:30 pm
I don't know how to do that. Con some pody help me out?
I have problem in this code ,I couldn't figure out method to display days in order:
Code:
public void advance(int m){
        int totalminutes = (hours*60)+(minutes+m);
        hours = (totalminutes/60)%24;
        minutes=totalminutes%60;
         day_of_week=totalminutes%9;
    public void reverse(int m){
	int totalminutes = (hours*60)-(minutes-m);
        hours = (totalminutes%24)/60;
         day_of_week=totalminutes%14;
Here entyer the cod for my homework :
Code:
package clockdriver;
 * @author
public class ClockDriver {
     * @param args the command line arguments
    public static void main(String[] args) {
        Clock MyClock = new Clock("Thursday", 12,0); // Instantiate a clock object
	System.out.println(MyClock); // Should display: Thursday, 12:00 p.m.
        System.out.println(); // print blank line
        MyClock.advance(150); // advance time 150 minutes (2 hours 30 minutes)
	System.out.println(MyClock); // Should display: Thursday, 2:30 p.m.
        MyClock.advance(585); // advance time by 585 minutes (9 hours 45 minutes)
	System.out.println(MyClock); // Should display: Friday, 12:15 a.m.
        MyClock.advance(10080); // advance time by 10080 minutes (7 days)
        MyClock.reverse(585); // reverse time by 585 minutes (9 hours 45 minutes)
        MyClock.reverse(17280); // reverse time by 17280 minutes (12 days)
	System.out.println(MyClock); // Should display: Saturday, 2:30 p.m.
    } // end of main
} // end of class ClockDriver
class Clock{
     * Objects of this class represent time (in hours and minutes) *
     * The time data is stored in 24 hour (HHMM military format)   *
    private int day_of_week; // valid range of values is 1 thru' 7
    private int hours; // range of values is 0 thru' 23
    private int minutes; // range of values is 0 thru' 59
 private static final String[] Days={"Saturday","Sunday","Monday","Tusday","Wensday","Thusday","Friday",};
    public Clock(String S, int h, int m){
	day_of_week = Integer.parseInt("6");
        hours=0;
        minutes=0;
    @Override
    public String toString(){
        String s= Days[day_of_week - 1]+","+
                (hours>12? hours-12 : hours<1? 12 : hours) +
                ":" + (minutes<10? ("0"+minutes) : minutes) +
                (hours>=12? " am" : " pm");
/*+ (hours>12? hours-12 : hours<1? 12 : hours) + ":" +
        (minutes<10? ("0"+minutes) : minutes) + (hours>=12? " pm" : " am"));*/
       return(s);
my currently result is
Code:
run:
Thusday,12:00 pm
Thusday,2:30 pm
Thusday,12:15 am
Thusday,12:15 am
Sunday,12:30 pm
Sunday,12:30 pm
BUILD SUCCESSFUL (total time: 0 seconds)
I don't understand what you're doing in the last lines of these two methods:
Code:
In the first method, why are you calculating totalminutes & 9? In the second method, why are you calculating totalminutes & 14?
There are 1,440 minutes in a day (24 * 60), but your clock starts at 12:00pm (noon), so if totalminutes > 720 but less than 2160, you need to increment the day to Friday. If totalminutes is between 2160 and 3600, you need to increment the day to Saturday. And so on.
Can you please write miss code that , I need. I really stuk with it and I have no time. due time tonight. I tryed by this way but it doesn't work.
Code:
               day_of_week=(24*60)*7+10080/8;
         day_of_week=(24*60)*7+10080;
This isn't an improvement. The first value that is coming up wrong in your program is when the clock is advanced 585 minutes. The program should display Friday 1:45 am, not Friday 12:15 am as your code comment shows. Work through by hand what you need to calculate to arrive at that day and time. Then write your code to do the same.
Is this the way how to start I keep change minutes from 60 to 120 to 180 and time changed but I didnt reach the right one:
Code:
int totalminutes = (hours*558)+(minutes+m);
can you please give me example, I really don't understand. can you write code for me as example. I worry about time.
I did houre*558 to change time and then it will change days. This is what I thought it will work!
Code:
        int totalminutes = (hours*585)+(minutes+m);
               day_of_week=totalminutes%8;
	int totalminutes = (hours*17280)-(minutes-m);
result:
Code:
run:
Thusday,12:00 am
Thusday,2:30 am
Saturday,5:45 am
Sunday,1:30 am
Monday,12:15 am
Saturday,12:45 am
If the current time and day is 2:30pm Thursday, and you advanced the clock by 585 minutes, show me how you would figure out the correct time and day.
I DON'T want to see code.
