How to Express Non-regular Prior Distributions by Mathematical Formula
  • Context: Undergrad
  • Thread starter Thread starter nizi
    Support
This discussion focuses on expressing non-regular prior distributions in Bayesian logistic regression models, specifically using the uniform distribution for parameters β₀ and β₁. The participants agree that while the notation β₀, β₁ ∼ Uniform(-∞, ∞), i.i.d. is mathematically valid, it poses significant challenges in practical applications due to the uniform distribution's lack of tails, leading to unreliable posteriors. The consensus emphasizes the necessity of providing robust theoretical justification for using such priors, as improper priors complicate numerical simulations and convergence.
  • Understanding of Bayesian statistics and logistic regression
  • Familiarity with prior distributions and their implications
  • Knowledge of the logistic function and its application in regression models
  • Experience with statistical simulation techniques
  • Research the implications of using improper priors in Bayesian analysis
  • Explore alternative prior distributions for Bayesian logistic regression
  • Learn about the convergence issues in Bayesian numerical simulations
  • Study the theoretical foundations of uniform distributions in statistical modeling
Statisticians, data scientists, and researchers involved in Bayesian modeling, particularly those working with logistic regression and prior distribution selection.
nizi
This time I target the following two-class Bayesian logistic regression as statistical models.
$$y_n \sim \mathrm{Bernoulli}(q_n)$$
$$q_n = \sigma (\beta_0 + x_n \beta_1)$$
where ##n## is the index of the data and ##\sigma## is the logistic function.
Since I assume ##\beta_0 + x_n \beta_1## as the linear predictor (the independent variable of the logistic activation function), I have two parameters ##\beta_0## and ##\beta_1##, and I want to express that their prior distributions independently follow a non-regular uniform distribution, the support of which each probability density function is the set of real numbers.
Is it appropriate to write
$$\beta_0, \beta_1 \sim \mathrm{Uniform}(-\infty, \infty), i.i.d.$$
in this case?
I'm particularly concerned about the appropriateness of writing i.i.d.
If there is a more appropriate way to express this, please let me know.
The iid is fine. But this prior will require some justification. The uniform distribution will be really bad here because it has no tails so the posteriors are almost guaranteed to be unreliable. And starting with this prior is numerically impossible. And approximating it will probably have poor convergence.
If you do use this prior you will need to provide rock-solid theoretical arguments why the priors must come from a uniform distribution and none other. And if you have that much information then surely the non-regular version is not correct.
I appreciate your thought-provoking response very much.
My question has been answered.
What I was particularly concerned about is whether I can use the term "i.i.d." here, even thought ##x_n## has certain units, e.g. kg.
This is because the units of ##\beta_0## and ##\beta_1## are different in this case.
As you mentioned, it's impossible to use this improper prior in a numerical simulation, so it's only an mathematical expression.
  • · Replies 125 ·
21K
  • · Replies 150 ·
22K
10K
