How to find a point on line of intersection of 2 planes?
This discussion focuses on finding a point on the line of intersection of two planes using linear algebra techniques. Participants emphasize the importance of obtaining the normal vector through the cross product and suggest methods for eliminating variables to express components in terms of a parameter, t. A specific example is provided with the equations 2x + 2y + z = 6 and 3x + 3y + 2z = 2, demonstrating how to manipulate these equations to find a solution. The discussion concludes with a method for determining a point on the line by setting one coordinate to zero and solving for the others.
  • Understanding of linear algebra concepts, particularly systems of equations.
  • Familiarity with vector operations, including the cross product.
  • Knowledge of parametric equations and their applications in geometry.
  • Ability to manipulate equations and matrices, including row reduction techniques.
  • Study the Rouché-Capelli theorem to understand the conditions for the existence of solutions in linear systems.
  • Learn about the geometric interpretation of the intersection of planes in three-dimensional space.
  • Explore matrix operations, specifically how to perform row reduction to find solutions to linear equations.
  • Investigate the application of parametric equations in computer graphics and game development.
Mathematicians, computer scientists, game developers, and anyone interested in computational geometry or solving systems of linear equations.
NotASmurf
Hey all, for some software I'm writing a sub problem of a bigger math problem I have is that I need to find the line of intersection of two planes, One can obtain the normal via the cross product but I am stuck at how to find a point on that line as they're seems to be too many variables involved, Any help appreciated, thanks.
Mathematics news on Phys.org
No, it's a personal one, it's for a game.
"I can see that both planes will have points for which x = 0." Is there no technique? "I can see" isn't very mathamatical. But thanks.
What do you mean by mathematical?
This is how people solve this sort of problem by find a point and the direction vector and putting them together to find the line.
This is easily converted to code.
So find variables with same coefficients or if not use lowest common multiple to get them common, then eliminate a variable, set z=t and express each component in terms of t, this avoids using cross product?
What if you have 2x+2y+z=6 and 3x+3y+2z=2
multiply eqn 1 by 3 and eqn 2 by 2
then you get 6x+6y+4z=4 and 6x+6y+3z=18
then the x's cancel but so do the y's then you get a numerical answer for z?? then do you set x or y as t then?
Say you have two normal vectors, \vec{n}_1 = (a_1, b_1, c_1), \vec{n}_2 = (a_2, b_2, c_2) as well as two position vectors \vec{p}_1 = (x_1, y_1, z_1), \vec{p}_2 = (x_2, y_2, z_2). The intersection of two planes defined by these vectors is all position vectors \vec{x} = (x, y, z) that satisfy
\left\{\begin{array}{ccc}<br /> (\vec{x} - \vec{p}_1) \cdot \vec{n}_1 = 0\\<br /> (\vec{x} - \vec{p}_2) \cdot \vec{n}_2 = 0\end{array}\right..<br />This is equivalent to solving the linear algebra problem\left [\begin{array}{ccc}<br /> a_1 &amp; b_1 &amp; c_1 \\<br /> a_2 &amp; b_2 &amp; c_2 \end{array}\right] \left [\begin{array}{ccc}x \\ y \\ z\end{array}\right] = \left [\begin{array}{ccc}<br /> \vec{p}_1 \cdot \vec{n_1} \\<br /> \vec{p}_2 \cdot \vec{n_2} \end{array}\right] which can be written as \vec A \vec x = \vec b.
Assuming a solution exists (Rouché-Capelli theorem), the solution should be in the form \vec x = k \vec r + \vec p. Hence \vec A (k \vec r + \vec p) = \vec b where \vec p is a particular solution and \vec r is a homogeneous solution that spans the null space of \vec A. As has been pointed out, \vec r = \vec{n}_1 \times \vec{n}_2, \vec{r} \neq \vec 0 is one such solution. In the case when the two normal vectors are parallel, then any non-zero vector spanned by the basis of one of the planes will do like say a vector projection of one of the standard unit vectors onto the plane (keep switching to find one that's non-zero).
To find a particular solution, simply remove a linearly dependent column vector and set it's corresponding variable to zero and solve the matrix equation. For instance, if the first column is linearly dependent, remove it and let x = 0. You then solve the equation
\left [\begin{array}{ccc}<br /> b_1 &amp; c_1 \\<br /> b_2 &amp; c_2 \end{array}\right] \left [\begin{array}{ccc}y \\ z\end{array}\right] = \left [\begin{array}{ccc}<br /> \vec{p}_1 \cdot \vec{n_1} \\<br /> \vec{p}_2 \cdot \vec{n_2} \end{array}\right] to get a particular solution.
EDIT:
Alternatively, you can get everything by reducing the augmented matrix [\vec A|\vec b] to a reduced row echelon form. Then, each leading coefficient is located on a column i. The ith coordinate of the particular solution is therefore the augmented element on the same row. The coordinates of the homogeneous solution is given by the negatively inverted value of the element on the same row in a linearly dependent column j, with the jth coordinate being 1. For instance, the augmented matrix
\left [\begin{array}{ccc}<br /> 1 &amp; 2 &amp; 3 &amp; 5\\<br /> 1 &amp; 2 &amp; 4 &amp; 9\end{array}\right]has the reduced row echelon form
\left [\begin{array}{ccc}<br /> 1 &amp; 2 &amp; 0 &amp; -7\\<br /> 0 &amp; 0 &amp; 1 &amp; 4\end{array}\right] hence the full solution is
\vec x = \left [\begin{array}{ccc}<br /> -7\\0\\4\end{array}\right] + k<br /> \left [\begin{array}{ccc}<br /> -2\\1\\0\end{array}\right]<br />
Likes NotASmurf
Thanks everyone
Let (u,v,w) be the cross product. You want to find a point (x,y,z) so that (x,y,z)+t(u,v,w) is the parametric form of the line. Determine which coordinate among u,v,w has the largest magnitude. Let us say it is u. Then set x=0 in the expressions for the two planes and solve for y and z.
Using the coordinate with the largest magnitude avoids problems with singularities.
I noticed you decided to start a new post. I hope this clarifies it for you.
Likes NotASmurf
