How to find minimum possible mass
6 replies · 2K views · last reply
ssarpal
A block of mass m moving at a speed 4 m/s collides with a block of mass 2 Kg initially at rest. The force during collision varies as the function F = A*sin^2(Bt). The collision lasts for 1 ms.
Find the minimum possible mass m?
##A = 10^4 N##
##B = 1000\pi \hspace{2mm} rad/sec##
Change in momentum is equal to the integral of force with respect to time.
Unfortunately, this is not the right answer.
The integral gives you the impulse ##J## which is the momentum change of the unknown mass. After the collision, this mass will still be moving with velocity ##v_1## and the 2 kg will also be moving with velocity ##v_2## because it received impulse ##J## in the opposite direction. Do you see how to tie all this together?
Did it bother you that you were asked to find a minimum, but you did not go through such a step?
I think that means
##mu_1 = mv_1 +m_2v_2##
where ##u_1## = 4 m/s and ##m_2## = 2 Kg
Am not sure if ##v_1## and ##v_2## are needed to solve this?
Yes, was wondering where it could be used, am not sure how though.
Perhaps you need to think about energy?
The first thing to ask oneself is: What are the possible final velocities of each object and what is the mass m for each of those velocities?
