How to find the shortest distance to a hyperboloid, etc?
  • Thread starter Thread starter RJLiberator
    Shortest distance
The discussion focuses on finding the shortest distance from the hyperboloid of two sheets defined by the equation z² = x² + y² + 1 to the point P(0, 1, 0). The critical point identified is (0, 1/2, √5/2), which minimizes the distance. Additionally, due to the symmetry of the hyperboloid, the second point at (0, 1/2, -√5/2) also attains the same minimum distance. The analysis confirms that these are the only points on the surface of the hyperboloid that yield the shortest distance to point P.
  • Understanding of hyperboloids and their equations
  • Knowledge of partial derivatives and critical points
  • Familiarity with distance functions in three-dimensional space
  • Concept of symmetry in geometric shapes
  • Study the properties of hyperboloids, particularly the hyperboloid of two sheets
  • Learn about optimization techniques using partial derivatives
  • Explore the geometric interpretation of critical points in three dimensions
  • Investigate the implications of symmetry in mathematical surfaces
Students studying multivariable calculus, mathematicians interested in geometric optimization, and educators teaching concepts related to hyperboloids and distance minimization.
RJLiberator
Consider the hyperboloid of two sheets: z^2=x^2+y^2+1
and a point P(0, 1, 0). Find the shortest distance between the hyperboloid and the point P. Also, find coordinates of all points on the surface for which this distance is attained.
So, I first used the distance function with the point P.
(x-0)^2+(y-1)^2+(z-0)^2
and this simplified (with the use of the equation z^2=x^2+y^2+1 to:
2x^2+2y^2-2y+3=f(x,y)
I then took the partial derivatives with respects to x and y
fx = 4x
fy = 4y-2
These equal 0 when x = 0 and y = 1/2. This is the ONLY critical point.
I then found the z value with original function so (0, 1/2, sqrt(5)/2) is the point.
I then found the distance to (0,1,0) through subtraction. (0, 1/2, -sqrt(5)/2) = Shortest distance from hyperboloid to point P.
Now I'm pretty sure that this is correct, but how do I go about finding the coordinates of all points on the surface for which the distance is attained? I'm struggling to start here. Any tips on this would be great.
I think you are done.
Interesting. I had this hunch as well. It didn't make sense that there would be more coordinates if that was the only critical point.
In a sense, they were simply testing conceptual understanding with that add-on then.
Let me just clarify my understanding: Since there is only one critical point on the hyperboloid that minimizes the distance in such a way that it becomes the shortest possible distance from the hyperboloid and the point P, then that is all possible points on the surface for which the distance is attained.
Excellent.
Thank you.
Is that the only z value?
Oi, perhaps +/- sqrt(5)/2 Eh? Yes, that exists because z^2. But then, because that exists that is a second point similar distance to point P.
Yes. (Picturing it helps. You see the symmetry about the XY plane.)
Yes, I was curious about this as I made a poster for hyperboloids with two sheets and noticed that there should be an opposite point that is symmetrical. Thank you.
Oops, good point, I missed the other sheet as well.
