How to get data points from plot?
  • Context: Mathematica
  • Thread starter Thread starter member 428835
    Data Plot Points
7 replies · 2K views
member 428835
Hi PF!
I used NDSolve to find the solution to a differential equation. I then plotted the solution in mathematica. However, I would like to be able to plot this in LaTex, specifically in TikZ. Can anyone help me here?
Thanks so much!
It is usually better to get a screen grab of your plot then embed in your LaTeX document as a graphic.
joshmccraney said:
Hi PF!
Thanks so much!
The output of NDSolve is an InterpolatingFunction object. If the InterpolatingFunction object is named "f" then "f[[2]]" will produce a table containing the interpolation points.
Hi Dale!
I have the following code
Code:
a=0;
s = NDSolve[{y[x] y''[x] + 2 (y'[x])^2 + x y'[x] - 2 a/(1 + a) y[x] ==
      0, y[1] == .0000000000001, y'[1] == -1/2}, y, {x, 0, 3/2}];
s[[2]]
but then I receive the response "Part 2 of..." followed by a long error message. Am I doing something wrong?
Thanks so much for your help!
You could simply evaluate the interpolated function at the desired points:
Code:
Table[{x, Evaluate[y[x] /. s][[1]]}, {x, 0, 3/2, stepsize}]
or
Code:
Table[{x, s[[1, 1, 2]][x]}, {x, 0, 3/2, stepsize}]
The interpolating function itself is nested within [[1,1,2]] of the NDSolve output.
Very nice Fightfish! Inputting these into latex will be the worst, but this is a good way to get it done! Thanks!
Actually, it took no time at all! Once copy-pasting mathematica's output, I used the "replace and find" search key and replaced "}" with ")" and the commas after the parenthesis with "to" etc. Thanks a ton!
I like Fightfish's approach better. It turns out that my approach is not as simple as I has remembered.
