How to Handle Non-Normal Residuals in Multiple Regression Analysis
  • Context: Undergrad
  • Thread starter Thread starter bradyj7
    Normal
8 replies · 4K views
bradyj7
Hi there,
I have performed a multiple regression analysis and I am checking the assumptions. The normal probability plot is not exactly a straight line, but is it okay? If you were looking at the plot would you be satisfied hat the normality assumption is valid? https://dl.dropbox.com/u/54057365/All/residuLPLOT.jpg
I performed an Anderson Darling test on the residuals and the residuals were found not to be normal. What would you do in this case? Would you transform some of the predictors? Would you transform them all or just some?
I'd appreciate any comments.
Thanks
John
If you are trying to solve a real life problem, you should consider the realities of the problem and reveal them to your would-be advisors. For example, what are the physics? Is there some physical law that predicts the curve from which you compute the residuals? Is the precision of your measuring equipment limited to a certain number of digits?
There aren't any mathematical laws that can specify a correct answer to your question if it is abstracted to a few graphs. (Of course, there can be lots of suggestions about how to make the graphs look different. I'm just saying that there aren't mathematical theorems that prove one way is better than another.)
Last not least there are statistical test to decide whether to accept normality or not. I guess they would reject normality in your case. The question is whether this is of any relevance for your problem.
If that first plot is a QQ plot with reference to a standardized normal, I think your assertion will be wrong.
But OP, as others have said, you need to put this into the context of the problem and the data and what both of them actually relate to physically, experimentally, and intuitively.
Thank you for suggestions. Much appreciated.
not normal. perform some transformation such as log, reciprocal etc to the variable.
bradyj7 said:
Hi there,
Thanks
John
The residuals are skewed, so they aren't normal. The mode should be around zero but it is actually -0.8.
You can transform dependent variable.
But there is another possibility about data problem. There may be some extreme outliers in the data. Try to remove or adjust the outlier first by some appropriate method such as "Winsoriztion".
