How to increase oxidation in something
  • Thread starter Thread starter TheQuietOne
    increase Oxidation
The discussion revolves around the concept of increasing the rate of oxidation in various objects. Participants explore the definition and implications of oxidation, as well as potential methods to achieve this increase, while addressing ambiguities in the original question.
  • Some participants question the clarity of the phrase "increase oxidation in an object," suggesting it lacks specificity.
  • One participant clarifies that increasing the oxidation state involves losing electrons and that the method depends on the specific object in question.
  • Another participant points out that "rate of oxidation" could refer to various processes, such as combustion in wood or fuel consumption in engines, highlighting the ambiguity of the term.
  • A suggestion is made to immerse the object in pure oxygen and apply heat, such as with lasers, to potentially increase oxidation.
  • A later reply warns about the dangers of heating an oxygen tank, indicating safety concerns related to the proposed method.
Participants generally express disagreement regarding the clarity and specificity of the original question. Multiple competing views on how to interpret and approach the concept of increasing oxidation remain unresolved.
Participants note that the term "oxidation" is often used in specific contexts, such as atomic or molecular levels, rather than macroscopic objects. There is also a lack of consensus on the exact meaning of "rate of oxidation."
TheQuietOne
Not sure if this is Chemistry or not, but how would one increase oxidation in an object?
Chemistry news on Phys.org
Define "increase oxidation in an object". As worded this statement doesn't make sense.
Sorry, I meant increase the rate of oxidation in an object.
Increasing the oxidation state means that it would need to continue losing electrons. How to do that depends upon the "object" that you are wondering about, as there various oxidants that can be used. Can you be more specific?
I am afraid it still absurdly ambiguous.
"Rate of oxidation in an object" can be the speed at which wood is burnt in my fireplace, speed at which the fuel is consumed in a car engine, the speed at which battery works, or the speed at which I am burning glucose when riding on a bike (plus some).
Do you see why it is not possible to even try to answer your question?
Going through some terminology here may be of assistance for you. The term oxidation already implies a change by its very definition, so your question does carry a sort of roundabout meaning. I did still attempt to understand what you are trying to ask though. This term is probably best used in the context of atoms or molecules (not macroscopic objects).
https://en.wikipedia.org/wiki/Redox
Immerse your object into (as best as can be achieved), 100% pure Oxygen?.
Maybe then heat it up with lasers?
Yes! thank you rootone! ( sorry about my lack of chemistry knowledg to y'all)
...careful not to heat an oxygen tank up with a laser, it could explode.
