How to Integrate Upper Bounds with Circumscribed Rectangles
9 replies · 3K views · last reply
tmclary
[SOLVED] Upper Bounds Integration
Integrate y=4x from 2 to 5 using the limit with circumscribed rectangles.
A=lim(n to inf.) Summation of f(xsubi) times delta (xsubi)
A=lim(4/n)(4/n)(4)(2+3+4+...+(n+1))
=64/n^2((n^2+3n)/2))= 32lim((n+3)/n)) =32. But from integration the answer is obviously 48. What am I doing wrong? (Sorry about lack of typo skills-newbie)
why do you think the answer is obviously 48?
Your answer isn't correct again thout..
well i got 42 as my answer, either by directly integrating
[tex]\int_2^5 4xdx[/tex] and also by using Rieman sums.
I'll try to post my work, on my next post.
Sorry-wrong limits!
Sorry! The limits were 1 to 5, not 2 to 5!
we want to calculate
[tex]\lim_{n\to\infty}\sum_{i=1}^{n}f(\epsilon_i)\delta x_i[/tex]
now let us create n mini segments on the segment [2,5]
that is let the points be
[tex]x_0=2,x_1,x_2,...x_i_-_1,x_i,...,x_n=5[/tex]
Now our concern is to determine what our function will be.
First let's notice certian facts:
[tex]\delta x_i=x_i-x_i_-_1[/tex] also let [tex]\epsilon_i=x_i[/tex]
this way we have:
[tex]\epsilon_i=\delta x_i+x_i_-_1[/tex]
also: [tex]\delta x_i=\frac{5-2}{n}=\frac{3}{n}[/tex]
Now, for to determine our function let's try some values for i=1,2,3,...
[tex]f(x_1)=4\left(\frac{3}{n}+2\right),f(x_2)=4(\frac{6}{n}+2),f(x_3)=4(\frac{9}{n}+2),..., f(x_i)=4(\frac{3i}{n}+2)[/tex]
Hence:
[tex]\int_2^54xdx=\lim_{n\to\infty}\sum_{i=1}^{n}4\left(\frac{3i}{n}+2\right)\frac{3}{n}=...=42[/tex]
Well, then do the same thing as i did here, just take into consideration that you have the lower limit 1, in this case. I am not going to troube to go the same route again, i think you can do it now. If you can't ask again.
cheers!
Well it doesn't change a lot by the way, the difference is that now you'll have
[tex]\delta x_i=\frac{4}{n}[/tex] and
[tex]f(x_i)=4\left(\frac{4i}{n}+1\right)[/tex]
and the answer will be 48.
Thanks very much for your replies- I'm still stuck expanding the summation- will attempt another query when I have time, and can clarify.
Got it- I wasn't adding the 1 to the 4/n. Thanks again for your answer.
I tried to post a detailed answer, including how the summation expanded and all that stuff, but after i typed it all, i don't know for some crappy reason it did not show up. Anyways, I'm glad you got it !
