How to interpret the hazard function and its integral?
4 replies · 2K views
Eclair_de_XII
"Suppose that the accident rate for one workplace ##A## is ##k## times the rate of another workplace ##B##. In other words, ##\lambda_A(t)=k⋅\lambda_B(t)##. Conclude that the probability of no accidents in workplace ##A## is the probability of no accidents in workplace ##B## to the ##k##-th power.
In other words, if ##\lambda_A(t)=k⋅\lambda_B(t)##, then ##P(X^c|A)=P(X^c|B)^k## where ##X## denotes the event of an accident."
Hazard function: ##\lambda(t)=\frac{F'(t)}{1-F(t)}##
-denotes the probability of an accident happening on ##t+\delta t## given no accidents have happened by ##t##
I'm having trouble interpreting this function, honestly. I mean, what do I get if I integrate ##\lambda(t)##? Is it not just the probability of an accident happening between some initial time ##t_0## and some final time ##t_f## for either workplace? What I got, through integration, was:
(Assuming ##\lambda## is constant)
##\lambda_B(t)=\frac{F'(t)}{1-F(t)}##
##\lambda_Bt=\frac{F'(t)}{1-F(t)}dt##
##\lambda_Bt=\int_{t_0}^{t_f} \frac{F'(t)}{1-F(t)}dt=P(X|B)##
##P(X|B)=-\int_{t_0}^{t_f} \frac{F'(t)}{F(t)-1}dt=-\int_{t_0}^{t_f} \frac{F'(t)}{F(t)-1}dt=-ln|F(t)-1|=ln|F(t_0)-1|-ln|F(t_f)-1|=ln|\frac{F(t_0)-1}{F(t_f)-1}|##
Then what I get for ##P(X|A)## is:
##P(X|A)=-k⋅\int_{t_0}^{t_f} \frac{F'(t)}{F(t)-1}dt=-k⋅ln|F(t)-1|=k⋅[ln|F(t_0)-1|-ln|F(t_f)-1|]=k⋅ln|\frac{F(t_0)-1}{F(t_f)-1}|=ln|\frac{F(t_0)-1}{F(t_f)-1}|^k=P(X|B)^k##
I'm confused on how ##\lambda(t)## works... Can anyone tell me how to interpret its integral? Can anyone tell me if I integrated the wrong function?
Can you start by telling us what ##F(t)## and ##F'(t)## are? I think CDF and PDF, but of what?
Given the ##\lambda##'s in here, I have a strong suspicion we're talking about Poissons and exponential inter-arrivals, but maybe this is about more general renewal processes or something completely different... To the extent its Poisson related there should be some simplifications that make this a lot easier.
Well, ##F(t)## is the c.d.f. describing the probability of having an accident before time ##t##. So... ##F(t)=Pr(T \leq t)## and ##F'(t)## is the derivative of that. So ##F(t)## is the area under ##F'(t)## but above ##F(t)=0##.
Note that
$$\lambda(t) = -\frac{G'(t)}{G(t)},$$
where ##G(t) = P(T > t) = 1 - F(t)## (for a lifetime ##T## with hazard function ##\lambda(t)##).
Thus,
$$G(t) = \exp \left(-\int_0^t \lambda(s) \, ds \right). $$
Now just compare ##G_A(t)## with ##G_B(t)##
Thanks, I figured it out.
