How to know which sign of root to take when finding the inverse of a function
5 replies · 4K views
madah12
find the inverse of
y=2x^2-8x
x>=2
I am in calculus b but forgot some of the algebra so I am not sure how to treat the root
I am skipping steps
y=2(x-2)^2-8
(y+8)/2=(x-2)^2
I know that x >=2
so f(2) =-8 and it is increasing so the range is [-8,infinity)
now how can I know which root to take?
As [itex]x\to \infty[/tex], [itex]y\to \infty[/tex] so when you find the inverse, this will still apply since they are images about the y=x line. Now can you see which root you should be taking?[/itex][/itex]
yes the positive one ,so is this a general rule for roots in inverse function?
Umm no, not necessarily. I just thought of it logically for the inverse of quadratics, so I haven't extended the same idea to other functions.
The best way would be to draw a rough sketch of the quadratic, then draw its inverse by flipping it about the line y=x and go from there. Pictures can really help.
What is true here is that, strictly speaking, f does NOT HAVE an inverse. In order to talk about an inverse for a function that is not one-to-one, you have to divide the domain into pieces, taking a different inverse for each "piece".
Here, [itex]y= 2x^2- 8x[/itex] and it is easy to see that its graph is a parabola, opening upward with vertex at (2, -8). We would need to divide this into two functions,
[itex]y= 2x^2- 8x[/itex] for [itex]x\le 2[/itex] and [itex]y= 2x^2- 8x[/itex] for [itex]x\ge 2[/itex]. Because your problem said "[itex]x\ge 2[/itex]" you are talking about the second.
To find the inverse, swap x and y to get [itex]x= 2y^2- 8y[/itex] and solve for y, perhaps by completing the square:
[tex]x= 2(y^2- 4y)= 2(y^2- 4y+ 4- 4)= 2(y- 2)^2- 8[/tex]
[tex]2(y- 2)^2= x+ 8[/tex]
[tex](y- 2)^2= \frac{x+ 8}{2}[/tex]
[tex]y- 2= \sqrt{\frac{x+8}{2}}[/tex]
[tex]y= 2+ \sqrt{\frac{x+8}{2}}[/tex]
How do I know to take the positive root? Because [itex]x\ge 2[/itex], after "swapping" x and y, became [itex]y\ge 2[/itex]. It is the positive root that makes y greater than or equal to 2. Taking the negative root, y would be "2 minus something".
Ahh good point.
