How to lower melting point of solids (TiO2)?
The discussion revolves around methods to lower the melting point of titanium dioxide (TiO2) without compromising its purity. Participants explore the effects of pressure and the intrinsic properties of solids in relation to melting points.
  • Exploratory, Technical explanation, Debate/contested
  • One participant inquires about potential methods to lower the melting point of TiO2, noting limitations of their electrical furnace and vacuum technology.
  • Another participant suggests that while pressure can influence melting points, the difference between atmospheric pressure and 10^-6 torr is negligible for solids, and significant changes would require much higher pressures.
  • A third participant asserts that the melting point is an intrinsic property of solids and cannot be altered without changing the material itself, reinforcing that pressure changes would have minimal practical effects.
  • A fourth participant agrees that altering the melting point would also change the composition of the material.
Participants generally agree that lowering the melting point of TiO2 without altering its composition is challenging, and there is no consensus on effective methods to achieve this.
Participants express uncertainty about the extent to which pressure affects the melting point of solids, particularly in the context of TiO2, and highlight the limitations of their experimental setups.
paul143
Hi,
I'm currently doing experiments on a 99.9% TiO2 source powder.
I was wondering if there is anyway to lower the melting point of this solid?
If possible, without compromising its purity.
I only have access to an electrical furnace that is capable of reaching a maximum
of 1200 degC only. Seeing that this material has a melting point of around 1800 degC,
I am kinda stuck right now.
By the way, I also have access to a relatively primitive vacuum technology. I tried
to seal my sample in a quartz tube then lowered the pressure inside up to around
10-6 torr. But I am not sure if this really has a significant effect, for I
have learned before that a change in pressure does greatly affect the boiling point
but I am not sure to the extent of its effect on melting point of solids.
Hope for any replies or suggestions.
Thanks very much for any information.
I'm not sure if there is much that you can do. Pressure can change the melting point, but the difference between atmospheric pressure and 10^-6 torr is quite negligible for a solid. If you could apply a pressure of 10-20 GPa that would be a different story, but it probably would not change the melting temperature in the direction you want!
The melting point is an intrinsic property of a solid, it can't be change without somehow altering the material itself. Lowering the pressure won't have any practical effect on a solid (nor would increasing it unless we are talking about REALLY high pressures).
i agree.by changing the melting point then the composition as well, will change.
54K
  • · Replies 17 ·
