How to magnetize water using super magnet?
  • Thread starter Thread starter oem7110
    Magnet Water
The discussion revolves around the concept of magnetizing water using a super magnet, exploring whether this process can alter the properties of water, such as reducing surface tension and viscosity, and breaking down molecular clusters. Participants consider both theoretical and practical implications of magnetism on water, with a focus on its chemical and physical properties.
  • Some participants suggest that placing a super magnet under a water bottle could magnetize the water, leading to various beneficial effects on its properties.
  • Others argue that water molecules have a permanent electric dipole but lack permanent magnetic dipoles, making them unsuitable for alignment in a magnetic field.
  • It is noted that water is diamagnetic, meaning it would create a weak magnetic field opposite to that of the magnet, thus not supporting the idea of magnetization.
  • Some contributions question whether a strong magnetic field could help break down water molecule clusters into smaller clusters, despite the lack of evidence supporting this claim.
  • Participants discuss the nature of magnetization, clarifying that water cannot retain a permanent magnetic moment after the magnetic field is removed.
  • There are claims that while water does not become magnetic, it may experience temporary effects under strong magnetic fields, such as alignment of protons, but these effects do not lead to permanent changes.
  • One participant suggests that breaking hydrogen bonds between water molecules might be possible, but this is met with skepticism and claims that such effects are not scientifically supported.
Participants generally disagree on the potential for magnetizing water and the effects of magnetic fields on its properties. Multiple competing views remain, with no consensus reached regarding the validity of claims about magnetization and its effects on water.
Limitations include the lack of empirical evidence supporting claims about magnetization effects on water, dependence on definitions of magnetization, and unresolved questions about the nature of molecular interactions in water under magnetic fields.
oem7110
If I place a super magnet under the bottom of my water bottle, will it magnetize the water I drink everyday?
Does anyone have any suggestions?
Thanks in advance for any suggestions
"After magnetization, the molecules line up in sequence “+-+-“ resulting in reduced surface tension, reduced viscosity, increased dissolvability, increased permeability and increased oxygen content hence making nutrients more readily available to our body, plants and soils. Water is then said to be biologically “alive”."
The water molecules has a permanent electric dipole. It does not have permanent magnetic dipoles so there is nothing to be aligned with the magnetic field.
The picture shown is may apply to a small particle of a ferromagnetic material like iron but not to water. Water is actually diamagnetic.
"Regular water molecules cluster without magnetization. Toxins and waste products build up causing molecule clusters to be much larger in size, increasing surface tension, increasing viscosity and limiting dissolvability and permeability of water. This results in poor water productivity as only a small percentage of water and nutrients applied are dissolved and made available for plants to take up at fine root zones. Magnetic treatment breaks up the molecules to smaller clusters allowing them to pass through plant capillaries more readily."
Does magnetization help to break down the water molecules cluster into smaller clusters?
nasu said:
What suggestions are you expecting? Do you have a question?
If you want to find more about the "super-water", you may start here:
http://www.chem1.com/CQ/clusqk.html
If I place a super magnet under the bottom of my water bottle, will it magnetize the water I drink everyday? that is my question.
No, water is a diamagnetic material and would weakly create a magnetic field opposite that of the magnet. The other effects you mentioned above are not a result of magnetization of water.
When water is close to super magnet, will this strong magnet field help to break down the water molecules cluster into smaller clusters?
Since water isn't magnetic I don't see how this could work.
Depends what you understand by "magnetize".
Usually it means to induce a permanent, macroscopic, magnetic moment in a sample.
This magnetic moment is retained even when the induced field is removed.
Such a thing does not happen with water. In this sense, water is not "magnetized" no matter how super is your magnet.
Water could be a semi-conductor if enough voltage trys to pass it through, let assume water is always being neutral, but the electron can free to move within water in liquid form, isn't it?
If I place a super magnet at the bottom of my water bottle, and shake it fast randomly, based on left-hand rule, all electrons will move in one direction, and all proton will move in another direction. With provided magnetic field from super magnet, would this force be generated to break large cluster of molecules into a smaller cluster?
Does anyone have any suggestions if I do it in this way?
Thanks everyone very much for any suggestions
Absolutely not. The electrons are bound to the molecules. They do not move to other molecules in water.
The answer is no. Your question is nonsense. I don't know where you got this information but it's wrong. What you're saying is complete pseudoscience. Stay away from whatever website you read that at. Go to the website nasu posted; that will dispel any misconceptions you may have. Here I'll post it again:
Electrons can free to move within its molecule, isn' it? not move to other molecules as I understand, so when super magnet is present near the water, all molecules' electrons will move to the same direction as shown on images, isn't it? If I shake the bottle, based on left-hands rule, moving electron will generate force under magnetic field and align each electrons within its molecule structure, it should not be wrong. Will this force break large cluster molecules into a small cluster?
Does anyone have any suggestions on any misconcept within my statement?
I don't know why the OP is so fascinated with magnets. Even though the spelling is not similar they are not magic. At any rate any attempt to magnetize water will quickly break down when the magnetic field is removed.
As you have been already told water is slightly diamagnetic, that means it naturally repels an applied magnetic field. And you can get the protons in water to temporarily align themselves. That is the principal used in proton precession magnetometers. When the induced field is dropped the protons will precess at a rate dependent on the natural magnetic field that is present. This takes a very powerful electromagnet, and it can be done with several molecules, water is one of them. It does not make the water magnetic. No magnet will affect water molecules to any noticeable degree. Once the magnet is taken away the water will almost instantly return to its original state. It will not break up water in anyway.
Subductionzon said:
... Once the magnet is taken away the water will almost instantly return to its original state. It will not break up water in anyway.
It does not break up water molecule H2O itself, but it breaks up the H-bond between H2O molecules and H2O molecule is still in stable stage. Does it make any sense on breaking large cluster of water into small cluster?
Does anyone have any suggestions on any mis-concept within my statement?
You've been told over and over this is non-sense. What exactly is your agenda pushing this?
You ask to be corrected or to be given advice and then declare anyone who responds as wrong and totally ignore them.
You cannot break that 'bond' because it's a simple dipole attraction.
I honestly have no idea how a high strength magnetic field would affect the dipole bonds between water molecules. I don't think it would do too much, but considering that the water is diamagnetic it does react to the field. The problem is that a magnetic field doesn't push or pull the electrons and protons at all. It simply causes them to spiral around the field lines. However a water molecule is neutral, so it wouldn't really do anything to the molecule as a hole other than to cause it to align its magnetic field anti-parallel to the magnets. Whether this would affect the bonds between molecules I can't say.
Do you have any evidence regrading the breaking of the hydrogen bonds in presence of a magnetic field? If you have a reference to a research paper, please share.
This is just as bad as his other topic about magnetising concrete
he won't listen to us guys, or go read the links given to him
and it just mindlessly drags on and on
Dave
Can the H-bond between H2O molecules be easily broken temporary by shaking water bottle fast randomly? I apply force into it, which is energy, can it break the H-Bond?
I just realized the bonds are already "broken", as the water is a liquid. However the molecules still attract each other, giving water its surfact tension, high boiling point, and other properties. It is only when water is in it's solid phase that they really bond strongy. Also, you aren't providing much energy to the water by shaking it.
And force is not energy by the way.
So, if the bonding is weak in liquid phase, and I place a super magnet at the bottom of my water bottle, based on left-hand rule, all electrons will move in one direction, and all proton will move in another direction. With provided magnetic field from super magnet, would this force be generated to break large cluster of molecules into a smaller cluster?
Neither the electrons nor the protons in the water molecules will move in any direction. The two forces would cancel out and the net result would be...nothing.
And I have no idea what "clusters" you are referring to. Do you have a link to something that explains what you want to know?
It mentions "the molecules line up in sequence “+-+-“ resulting in reduced surface tension, reduced viscosity ..."
[http]://www[dot]waterforlife[dot]net[dot]au/agriculture/how-it-works
Offhand I'd say they don't know what they are talking about, as water molecules don't do that. However I can't get to the link. It may be because I am at work and they do silly things with the internet here. Perhaps the article is talking about the molecules of the stuff in the water other than the water molecules?
From the website:
lol
Anyway, it does not cause molecules to line up in a sequence. Magnets have some small effect on water since it is diamagnetic iirc but the effect is gone once the magnetic field has been removed.
Furthermore, the diamagnetism of water under an applied magnetic field would not effect it's surface tension, viscosity, dissolvability, permeability, or oxygen content.
One way that you could reduce the attractions between individual water molecules is to use an anionic surfactant. This would have the effect of allowing the water to flow more 'freely' since the molecules do not tend to stick together so much also reducing the surface tension.
One common anionic surfactant is soap! This is one of the major effects of soap, since it allows the water to more readily act as a solvent for dirt and other things you don't want. You can see this effect by adding a tiny bit of soap to a droplet of water, which will cause it to flatten since it's surface tension has been decreased.
this thread is well beyond its use by date
I really wish the mods would just lock it
D
12K
  • · Replies 21 ·
