How to Measure Perpendicular Peculiar Velocity in Galaxy Simulations?
  • Context: Graduate
  • Thread starter Thread starter sketos
    Perpendicular Velocity
The discussion revolves around measuring the perpendicular peculiar velocity of galaxies in simulations, particularly in relation to radial peculiar velocities and how these can be calculated or inferred from available data. The context includes theoretical and practical aspects of galaxy simulations and observational data comparisons.
  • One participant questions how to measure the perpendicular peculiar velocity from simulation data, suggesting a possible relationship with radial velocity.
  • Another participant argues that peculiar velocity is typically related to angular velocity rather than radial velocity.
  • A different participant clarifies that in mock catalogues, individual galaxy velocities are known, including cosmological and observational redshifts, which can help measure the radial component of peculiar velocity.
  • There is a discussion about the definition of "peculiar velocity" and the need for a 3D velocity vector, which one participant states they do not have.
  • One participant expresses uncertainty about measuring the tangential component of peculiar velocity without a 3D velocity vector, suggesting their question may be arbitrary.
  • Another participant inquires about the availability of angular component data over time and suggests starting with a clear definition of the desired measurement.
  • A participant outlines their goal of computing pairwise peculiar velocity dispersion directly from simulated data, mentioning the formula for pairwise velocity and expressing the challenge of lacking orthogonal components of peculiar velocity.
  • One participant notes that a Doppler shift cannot be derived from motion perpendicular to the line of sight, raising a question about inferring such motion.
Participants express differing views on the relationship between peculiar velocity components and the available data, with no consensus reached on how to measure the perpendicular peculiar velocity or the implications of lacking certain data types.
Participants highlight limitations in the available data, including the absence of a 3D velocity vector and time-varying data, which may affect the ability to compute the desired measurements.
sketos
Hello,
I have data from a simulation of galaxies with various properties and I want to retrieve the peculiar velocity. If we want to relate with real galaxy surveys, what we can measure from real data is the radial peculiar velocity.
My question is, since we have a simulation i imagine we can measure the perpendicular velocity, but how?? Is there an equation which relates the perpendicular velocity of galaxies with other properties (i.e. the radial velocity)
P.S : to calculate the radial velocity I had the redshift of each galaxy with and without peculiar velocities.
Cheers
Space news on Phys.org
My question is, since we have a simulation i imagine we can measure the perpendicular velocity, but how?? Is there an equation which relates the perpendicular velocity of galaxies with other properties (i.e. the radial velocity)?
... depend son the data in the simulation.
The peculiar velocity is not usually related to the radial... but to the angular velocity.
... which you cannot do because you do not know how to get the peculiar velocity.
I don't think we are on the same page here. Since we are talking about mock catalogues of galaxies produced in simulation we have knowledge of individual velocity of the galaxies.
For example as I mentioned above we have the cosmological redshift of each Galaxy which corresponds to the velocity due to cosmic flow and I also have the observational redshift which corresponds to the velocity due to cosmic flow + radial component of the galaxy's peculiar velocity.
In other words I can actually measure the radial component of the peculiar velocity and my question remains... Is there a way to calculate the perpendicular peculiar velocity of each Galaxy and how?
The angular velocity has nothing to do with it.
In that case you need to start by defining "peculiar velocity".
You simulation data gives you a 3D velocity vector wrt something right?
The use of "radial component" usually implies there are angular components.
unfortunately i don't have such a vector in the data i received ( that would make my life easier ). I have distances, angular coordinates, observational and cosmological redshift and various other properties (i.e. luminocities, SFR, etc). I am not sure if i can measure the tangential component of the peculiar velocity ( so in a sense my question is quite arbitrary ).
Is there another way to compute, since i don't have a 3D velocity vector?
Do you have angular components data with time?
Maybe none of the galaxies has significant enough angular displacements?
But start with an 3xplicit definition of what you want to find.
My final goal is to compute the pairwise peculiar velocity dispersion. Normally in real galaxy surveys, one has to model the pairwise velocity dispersion with the two-point correlation function but since i have simulated data should be able to compute it directly.
If you define the pairwise velocity as: u12(r)=u1(x)-u2(x+r) then the pairwise velocity dispersion should be
σ12(r)=<(u12(r)-<u12(r)>)2/3>1/2
I thought to take as u2=ur2+up2, where ur and up are the radial and perpendicular components of the peculiar velocity (for each galaxy).
That would be straightforward if i had the orthogonal components of peculiar velocity for every galaxy . I don't have time varying data, it's just a mock catalog of galaxies. ( i know i am not giving you much to work it through but this is what i know so far )
You cannot derive a Doppler shift from motion perpendicular to the line of sight. So, I'm curious if you are asking if it can be inferred.
  • · Replies 23 ·
