How to resize and save a slice from a nii file as a PNG image in Python?
  • Topic: Python
  • Thread starter Thread starter BRN
    File
3 replies · 4K views
BRN
Hello everyone,
I have to extract a slice from a nii files and resize it with dimensions 256x256. Once this is done, I have to save it as a PNG image.
This is my code:
[CODE lang="python" title="slice from nii file"]def img_from_nii(height, width, n_slice, label, in_path, temp_path):
filenames = os.listdir(in_path)
for i in range(len(filenames)):
mri_file = in_path + filenames
img_data = nib.load(mri_file).get_fdata()
img_data = np.transpose(img_data, (2, 1, 0))
slice_2D = Image.fromarray(img_data[:, :, n_slice]).resize((height, width))
resized_slice = plt.matshow(slice_2D, cmap = 'gray', fignum = 0)
plt.axis('off')
plt.gca().set_axis_off()
plt.subplots_adjust(top = 1, bottom = 0, right = 1, left = 0, hspace = 0, wspace = 0)
plt.margins(0, 0)
plt.savefig(temp_path + label + '_ADNI_' + 'slc' + str(n_slice) + '_' + str(i + 1) + '.png')
plt.close()
print('dataset done!')[/CODE]
The problem is that PNG files are correctly created, but if you check the image size I do not get 256x256. How is it possible?
[CODE lang="python" title="check size"]
im = Image.open('./outputs/ADNI_png_temp/P_ADNI_slc150_3.png')
width, height = im.size
print('width:', width)
print('height:', height)[/CODE]
[CODE title="outputs"]
width: 432
height: 288
[/CODE]
How can I solve?
Thanks.
Have you looked at the images in Paint or something? From memory savefig pads the images the same way show() does.
Doesn't the Image class have a save method? Have you tried that?
If as Image class you mean that of Pillow, yes there is the save method, but it does not support 32-bit images and I lose quality.
By opening the image with any reader, I see the image in the correct size 256x256, but I also have two completely empty side bands.
I believe that the save method of Matplotlib does not provide for the cropping.
Oops! I forgot to update this post ...:-p
The problem was given by the 'Mathshow ()' function that adds additional spaces around the figure even if the axes are hidden.
I solved this way:
[CODE lang="python" title="slice from nii file ok"]def img_from_nii(height, width, n_slice, label, in_path, temp_path):
slice_2D = Image.fromarray(img_data[:, :, n_slice]).resize((height, width), resample = Image.Resampling.LANCZOS)
plt.imsave(temp_path + label + '_ADNI_' + 'slc' + str(n_slice) + '_' + str(i + 1) + '.png', slice_2D)
plt.close()
print('ADNI ' + label + ' dataset done!')[/CODE]
