How to See MAP Gas Flames in Bright Light?
  • Thread starter Thread starter Alt-Bringer
    Light
The discussion revolves around methods to visualize MAP gas flames in bright environments, particularly for applications in wood finishing. Participants explore various techniques and tools to enhance visibility without compromising safety.
  • One participant suggests that welding goggles may not be effective for viewing MAP gas flames due to their design for bright light, questioning the visibility of the flame in normal lighting conditions.
  • Another participant proposes adding salt to the flame, although they express uncertainty about its effects on woodwork.
  • A suggestion is made to use inexpensive IR night vision goggles, with the idea that cell phone cameras might detect near IR light from the flame, potentially aiding visibility.
  • Concerns are raised about using a phone as a visual aid due to safety and perception issues while working with fire.
  • A participant shares their experience that their camera does not significantly improve visibility compared to the naked eye, particularly in well-lit environments, and suggests finding ways to work under lower light conditions instead.
  • Another participant reiterates the idea of using salt, recommending borax as an alternative for its green flame and anti-fungal properties.
  • One suggestion includes using red light for background illumination to enhance visibility of the flame.
Participants express multiple competing views on how to effectively see MAP gas flames in bright light, with no consensus reached on a single effective method.
Participants mention potential negative effects of certain additives on wood, and there are unresolved questions about the effectiveness of various visual aids in bright environments.
Alt-Bringer
im trying to figure out if there's a way i can see the FULL flame from my torch (MAP)
without having to be in an potentially unsafe dark environment
as yall may know MAP gas burns a very light blue<teal colour that's very hard to see in normal light levels
using the interwebs, all I am finding is some neo-paganism stuff, and checking your stove pilot light stuff,
would welding goggles work in this capacity?
my thought is no, cause goggle is made to view things that are too bright to view safely,
whereas i think the issue of viewing flames is that the basic light level is too high?
im doing "flame finishing" on wood projects, and being able to see the whole flame would be helpfull
(in analogy, its like using a paint brush, except you can't see the bristles (or the paint on them)
any thoughts? thanks much
Computer science news on Phys.org
My first thought: salt the flame!
(However, I don't know if the salts has any effect on the woodwork...)
Some kind of inexpensive IR night vision goggles might work for you, as long as you can also see the visible light too. Maybe try looking through your cell phone camera to see if it picks up enough of the IR from the flame to be helpful. Cell phone cameras typically can see in the near IR spectrum (you can see the output from your IR TV remote control, for example).
hmm... how to try this out w/o dangling a $800 phone infront of my face while playing with fire
is there perception issues using a screen as your vision source?
LOL. I'd suggest just using your phone to look at the flame first, to see if it sees more of it than you do. If so, then you can think about getting a couple cheaper phone cameras with a similar IR characteristic, and making something based on them. Something like Google Glass maybe...
aww, camera doesn't really pick up any more than the eye (moto zforce 2, or first gen galaxy tab w/ ir cut filter removed)
it only really makes what you can see have a less "ghosty" effect
doesnt pick up any better in well lit environ either
finding a way to work under lower light is probably the easiest solution,
Maybe you should really try it with salt...
Ps.: since common table salt might has some negative effect on the wood, maybe try it with borax. Nice green flame and has some anti-fungal effects.
Try Red light for the general background and workstation illumination.
