How to Simplify Radicals in the Denominator?
To simplify the expression √8/3, first rewrite it as √(8/3) or multiply both the numerator and denominator by √3 to eliminate the radical in the denominator. This results in (√8 * √3)/(√3 * √3), simplifying to 2√6/3. The importance of removing radicals from the denominator is emphasized for clarity and standard mathematical practice. Ultimately, the expression can be further simplified by breaking down √24 into its prime factors.
kadavis2010
√8/3
none but there can't be any radicals in the denominator
=√8/√3=2√2/√3... what do i do now.. I can't have a radical in the denominator
Hint: Multiply both the numerator and the denominator by √3.
kadavis2010 said:
√8/3
Why must you not have a radical in the denominator? As you wrote the original expression, you indicated \frac{\sqrt{8}}{3}
Did you really mean to write \sqrt{\frac{8}{3}} ? You can simplify this by multiplying by \frac{\sqrt{3}}{\sqrt{3}}, which is just a factor of 1.
Yeah i meant what you said second... so would i have 24/9... with the square root of course.. but then would it be square root of 24 over 3?
Yes but you can rewrite \sqrt{24} = a \sqrt{b} What are a and b?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
