How to solve 1/6(3/4x-2)=-1/5
  • Topic:
  • Thread starter OMGMathPLS
    Fraction
10 replies · 3K views · last reply
OMGMathPLS
1/6(3/4x-2)=-1/5
The answer is 16/15
So to get that you multiply by reciprocal, right?
So you take the -1/5 and make it a 1 by fliping it over to -5/1.
Then you do to the other side the -5/1 and so that's -5/6(3/4x-2)=1
and then there's a -2 so you +2 it and do it to the other side so that's
-5/6(3/4x)=3
And then do you multiply the fractions by flipping one or do you move the x?
We are given:
$$\frac{1}{6}\left(\frac{3}{4}x-2\right)=-\frac{1}{5}$$
The first thing I would do here is multiply by LCM(5,6) = 30 to get rid of the denominators of 5 and 6:
$$30\cdot\frac{1}{6}\left(\frac{3}{4}x-2\right)=30\left(-\frac{1}{5}\right)$$
$$5\left(\frac{3}{4}x-2\right)=-6$$
Now, distribute the 5 on the left side...what do you get?
$\frac{1}{6}(\frac{3}{4}x-2)=-\frac{1}{5}$
$\frac{3}{4}x-2=-\frac{1}{5}*6$ (you flip the 1/6 and multiply)
$\frac{3}{4}x-2=-\frac{6}{5}$
$\frac{3}{4}x=-\frac{6}{5}+\frac{10}{5}$ (10/5 is equal to 2 you just want common denominators so you can easily add)
$\frac{3}{4}x=\frac{4}{5}$
$x=\frac{4}{5}* \frac{4}{3}$
$x=\frac{16}{15}$
If you distribute it on the left side
you get
5/1 (3/4x-2)
so you just multiply the fractions across
15/4 and -10/1 so -10
so it's 15/4x and -10
OMGMathPLS said:
1/6(3/4x-2)=-1/5
The answer is 16/15
-5/6(3/4x)=3
you cannot just pull out the -2 from the parenthesis and add it to the other side. you would first have to distribute the -5/6. what you want to do is isolate the x to solve for so try moving this from the left side of the equation (where the x is) to the other side.
you get
5/1 (3/4x-2)
Correct, so you have:
$$\frac{15}{4}x-10=-6$$
So add $10$ to both sides, then multiply through by $$\frac{4}{15}$$...what do you get?
you have 15/4x = 4
- - - Updated - - -
I don't know how you would isolate the x because it's really entangled in the ()
OMGMathPLS said:
you have 15/4x = 4
Correct, now multiply both sides by $$\frac{4}{15}$$...:D
Oh ok.
15/4(4/15)x = 4
x = 4/1 * 15/4
so that's x =60/4
OMGMathPLS said:
Oh ok.
15/4(4/15)x = 4
x = 4/1 * 15/4
so that's x =60/4
No, we have:
$$\frac{15}{4}x=4$$
Multiply through by $$\frac{4}{15}$$:
$$\frac{\cancel{4}}{\cancel{15}}\cdot\frac{\cancel{15}}{\cancel{4}}x=\frac{4}{15}\cdot\frac{4}{1}$$
$$x=\frac{16}{15}$$
ok. makes sense. thank you!
I guess it helps to write it out fully.
