How to Solve a Friction Problem with Statics
  • Thread starter Thread starter Jud
    Friction Statics
8 replies · 5K views
Jud
Determine the minimum horizontal force P required to hold the crate from sliding down the plane. The crate has a mass of 35kg and the coefficient of static friction between the crate and the plane is μs = 0.40
2. The attempt at a solution
Fx = P cos 30 - 343.35 sin 30 + F = 0
Fy = -P sin 30 - 343.35 cos 30 + N = 0
F = (μs)(lNl) = 0.40 (N)
so,
Fx = P cos 30 - 343.35 sin 30 + 0.40(N)
therefore,
Fy = -P sin 30 - 343.35 cos 30 = -N
so, F = 0.40 (P sin 30 + 343.35 cos 30)Sub into Fx,
P cos 30 - 343.35 sin 30 + 0.40 (P sin 30 + 343.35 cos 30) = 0Now solving for P I get 51.6 N, which is incorrect.
The answer is given. P = 49.5 N
Can anyone give me an indication of where I have gone wrong please.
Thank You.
You went wrong when you plugged numbers in your equations very early. Work out the result symbolically, then plug in the numbers.
P cos θ - mg sin θ + μs ( P sin θ + mg cos θ) = 0
Still yields the same answer?
This is not the result, this is just a step toward it. The result would have the form P = ... where the right hand side would not contain P.
P ( cos θ - mg sin θ + μs (sin θ + mg cos θ)) = 0
I'm having major trouble transposing.
P(-mg sin θ + μs (sin θ + mg cos θ)) = -cos θ
P(μs(sin θ + mg cos θ)) = -cos θ + mg sin θ
P(sin θ + mg cos θ) = -cos θ + mg sin θ / μs
P (sin θ) = (-cos θ + mg sin θ / μs) - mg cos θ
P = (-cos θ + mg sin θ / μs sin θ) - mg cos θ)
Open the brackets.
P cos θ - mg sin θ + μs P sin θ + μs mg cos θ = 0
Then collect like terms.
P (cos θ + μs sin θ) - mg (sin θ - μs cos θ) = 0
And this is just one step away from P = ...
voko said:
Open the brackets.
Sorry but I need bludgeoning in the head because I get 51.6N again, and I cannot see only one step available.
-P = (cos 30 + 0.4 sin 30) - 343.35 (sin 30 - 0.4 cos 30)
-P = -51.669N
P = 51.669N
Jud said:
[ IMG]http://questions.transtutors.com/Transtutors001/Images/Transtutors001_0f7b69b2-1e48-4ca4-8d27-89c487b0202a.PNG[/PLAIN]
Thank You.
Solving
P cos 30° - 343.35 sin 30°+ 0.40 (P sin 30° + 343.35 cos 30°) = 0
for P gives 49.4689 .
Check your algebra.
P (cos θ + μs sin θ) - mg (sin θ - μs cos θ) = 0 does not lead to that. P (cos θ + μs sin θ) means P multiplied by (cos θ + μs sin θ), not P plus (cos θ + μs sin θ).
