How to Solve a Probability Problem with Independent Stochastic Variables?
  • Thread starter Hummingbird25
    Probability
8 replies · 2K views · last reply
Hummingbird25
Hi People,
I have this Probability Problem which is given me a headach,
Given two independent Stochastic variables (X, Y) where X is Poisson distributed [tex]Po(\lambda)[/tex] and Y is Poisson distributed [tex]Po(\mu)[/tex].
Where [tex]\lambda[/tex], [tex]\mu > 0[/tex]. Let [tex]m \geq 0[/tex] and [tex]p = \frac{\lambda}{\lambda+ \mu}[/tex]
By the above I need to show, that
[tex]P(X=l| X+Y=m) = \left( \begin{array}{cc} l \\ m \end{array} \right ) p^l (1-p)^{(l-m)}[/tex]
Proof:
Its know that
[tex]\left( \begin{array}{cc} l \\ m \end{array} \right ) = \frac{l!}{m!(1-m)!}[/tex]
Wherefore the Binormal formula can be written as
[tex]\frac{l!}{(m!(l-m))!} p^l (1-p)^{(l-m)}[/tex]
for [tex]m \geq 0[/tex] I get:[tex]\frac{-(\frac{\lambda + \mu}{\mu})^{l} \cdot p^{l} \cdot \mu}{l!(l!-1) \cdot (\lambda + \mu)}[/tex]
Any surgestions on how to processed from here?
Sincerely Yours
Hummingbird25
No, no suggestions on how to proceed from there since you seem to be going at it backwards.
For any probability distribution, P(A and B)= P(A|B)*P(B) so that
P(A|B)= P(A and B)/P(B).
You are looking for P(X= l| X+ Y= m) so A is "X= l" and B is "X+ Y= m".
Then A and B is "X= l and X+ Y= m" which is the same as "X= l and Y= m-l". Now P(A and B)= P(X= l)*P(Y= m) .
Hi Hall,
Hello since X and Y is Poisson distributed then
[tex]P(x=l) * P(Y=m) = \frac{\lambda^l}{l !} e^{-\lambda} * \frac{\lambda^m}{m !} e^{-\mu}[/tex]
Is this the next?
Sincerley Yours
Hummingbird25
I think HallsofIvy made a small mistake in his last statement. He probably meant "P(A and B)= P(X= l)*P(Y= m-l)".
[tex]P(X=l) * P(Y=m-l) = \frac{\lambda^l}{l !} e^{-\lambda} *[/tex] (what do I need to add here then)?
Is this the next?
Sincerley Yours
Hummingbird25
[tex]P(X=l) * P(Y=m-l) = \frac{\lambda^l}{l !} e^{-\lambda} * \frac{\mu^{m-l}}{(m-l)!} e^{-\mu}[/tex]
And Hummingbird25, can I request that you check the question again? I tried solving the question and my answer was [tex]P(X=l| X+Y=m) = \left( \begin{array}{cc} m \\ l \end{array} \right ) p^l (1-p)^{(m-l)}[/tex]. Perhaps there is something wrong with my working...
Hello Pizzasky and thank You,
I looked at my assigment again I and discovered, that You result was the right one, I had (by mistake swapped l and m.
The right answer as You formulated:
[tex]\left( \begin{array}{cc} m \\ l \end{array} \right ) p^l (1-p)^{(m-l)}[/tex]Sincerely Hummingbird25
One last thing Pizzasky,
Which formula did You use to achive the binormal formula?
Sincerely Yours
Hummingbird25
Reply
You can use the substitution [tex]p = \frac{\lambda}{\lambda+ \mu}[/tex] to get the Binomial formula. Also, try to figure out what expression "1-p" corresponds to.
