How to Solve a Second Order Nonhomogeneous Differential Equation?
9 replies · 3K views · last reply
Math10
Find a particular solution of y"-5y'+6y=-e^(x)[(4+6x-x^2)cosx-(2-4x+3x^2)sinx].
None.
yp=e^(x)[(Ax^2+Bx+C)(cosx-sinx)]
y'p=e^(x)[(Ax^2+Bx+C)(-sinx-cosx)+(2Ax+B)(cosx-sinx)]+e^(x)[(Ax^2+Bx+C)(cosx-sinx)]
y"p=e^(x)[(Ax^2+Bx+C)(-cosx+sinx)+(2Ax+B)(-sinx-cosx)+(2Ax+B)(-sinx-cosx)+2A(cosx-sinx)]+e^(x)[(Ax^2+Bx+C)(-sinx-cosx)+(2Ax+B)(cosx-sinx)]+e^(x)[(Ax^2+Bx+C)(-sinx-cosx)+(2Ax+B)(cosx-sinx)]+e^(x)[(Ax^2+Bx+C)(cosx-sinx)]
subbing:
y"p-5y'p+6yp=4Ax^2e^xcosx+4Bxe^xcosx+4Ce^xcosx+2Ax^2e^xsinx+2Bxe^xsinx+2Ce^xsinx+2Axe^xsinx+Be^xsinx-10Axe^xcosx-5Be^xcosx+2Ae^xcosx-2Ae^xsinx=-e^x[(4+6x-x^2)cosx-(2-4x+3x^2)sinx]
So 4Ax^2e^xcosx=x^2e^xcosx
and therefore A=1/4.
But the answer to this problem is yp=e^(x)(x^2*cosx+2sinx). I don't think the coefficients I got are right. So what's the right initial guess for this problem?
How did you come up with your guess?
What made you think it was the best as opposed to some other form? I'm asking because writing down the form of particular solution is a cookbook process, yet you managed to come up with something different.
Since there's -e^x in the very front, so I got e^x as well in forming my guess yp. And then there's (4+6x-x^2) in front of cosx and same thing in front of sinx. So I got yp=e^(x)[(Ax^2+Bx+C)(cosx-sinx)].
The sine doesn't have the same factor multiplying it as cosine in the forcing function, or are you saying the cosine and the sine should both have a quadratic multiplying it? If the latter, why would you expect it to be the exact same quadratic?
The forcing function is the stuff that appears on the righthand side of the differential equation.
None.
subbing:
Have you checked whether the supposed "answer" actually solves the DE?
