How to Solve a Tough Trampoline Problem?
  • Thread starter Thread starter MrMath
    Trampoline
The discussion revolves around solving a complex trampoline problem involving a person jumping from a height and wanting to bounce for 30 seconds without exerting effort. Key considerations include the trampoline's properties, such as its spring constant and energy retention, as well as the effects of air resistance and friction on bounce height and duration. The importance of conservation of energy is emphasized, particularly regarding potential energy, kinetic energy, and elastic energy. The challenge lies in calculating the necessary parameters to ensure sustained bouncing while managing speed and energy loss. Understanding these dynamics is crucial for modeling the trampoline's behavior effectively.
MrMath
Tough trampoline problem...help?!
Hi there...i've recently been set a problem in one of my modules and need some help as to how to solve it, it goes as follows...a person jumps from a height (x) onto a trampoline, the person desires to bounce for 30 seconds without any effort of their own, but also their speed to not get too frightening. Assuming air resistance is proportional to speed, what should the trampolines properties be? What should the height of the platform be? And why?
Could someone please help me with this? Much appreciated!
MrMath
Welcome to PF. the forum guidelines ask that you do some work, or even at least post some remarks about your source of confusion. The trampoline is a big spring. Should it be a perfect spring, that is when there is no internal friction, would depend to the extent air resistance takes away enuf energy during the cycles in thirty seconds such that the last cycles landing doesn't stretch tramp enuf to impart enuf force to overcome weight? It can be calculated, but you might want to first do some research on falling bodies such as skydivers. We would need at least one other piece of info to even make a go of this problem.
Competition trampolines have very little wind resistance, usually they are like nets ("ozzie" / Australia beds), or the older style 1/4" canvas beds (1/4 inch wide strips with about 5/8 inch spacing between). Still, some energy is consumed with each bounce.
Even with 80% energy retension, 30 seconds would be a relatively long time to continue bouncing. I would suspect that a person's feet would no longer leave the surface of the tramp in much less time, although vertical motion would remain for quite a while longer after this.
Sorry, previously i failed to mention that i have actually done some work and realize that conservation of energy is vital to the problem with PE, KE and Elastic E being the three main types, the energy is obviously lost to friction, wind resistance and deformation causing the person to not bounce to the same height each bounce. Given a height i can obviously work out the max speed the person reaches (just prior to point of contact with the trampoline) but from there if i guessed at a spring constant how would i go about modelling the trampoline? and how would i work out how far it would bounce the person back up?
well before getting too much into the trampoline itself, two problems maybe to consider would be a horizontal spring, which itself is fixed to the wall, and is struck by a block of mass M. Then you could add friction if desired as some fx of velocity, normally V^2 for air resistance. Then you could turn the problem over vertically to consider gravity. I'd do all this if you haven't already before thinking about the actual tramp.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
