How to solve Asin(x) + Bcos(x) + Ctan(x) = 0
  • Thread starter Thread starter sarcaine
The discussion focuses on solving the trigonometric equation Asin(x) + Bcos(x) + Ctan(x) = 0. Participants emphasize transforming the equation into the quadratic form Atan^2(x) + Btan(x) + C = 0, where A, B, and C are derived from the coefficients a, b, and c. Key strategies include isolating sine and cosine terms and leveraging the identity sin^2(x) + cos^2(x) = 1 to simplify the equation. Graphical analysis of sine, cosine, and tangent functions is also recommended for better understanding the solution's behavior.
  • Understanding of trigonometric identities, particularly sin^2(x) + cos^2(x) = 1
  • Familiarity with quadratic equations and their solutions
  • Knowledge of the tangent function and its properties
  • Basic graphing skills for trigonometric functions
  • Learn how to derive coefficients A, B, and C from the original equation
  • Study methods for solving quadratic equations, specifically in the context of trigonometric functions
  • Explore graphical techniques for analyzing trigonometric equations
  • Investigate the implications of domain restrictions on solutions of trigonometric equations
Mathematicians, students studying trigonometry, and anyone involved in solving complex trigonometric equations will benefit from this discussion.
sarcaine
I need help in solving this equation
asenx+bcosx+ctanx=0
I solved it a few years ago but now I don't remember the right process.. The solution has to be in this way
Atan^2(x)+Btan(x)+C=0
where A = f(a,b,c), B = g(a,b,c) and C = h(a,b,c)
Thanks in advance
tan is sin/cos and cos^2+sin^2=1, that is sufficient to let you solve it.
Yes, these are the formulas I'm using. But I need some more help.. please show me some of the steps I can follow to solve it
I'm trying:
asin(x)+bcos(x)=-ctan(x)
a^2sin^2(x)+2absin(x)cos(x)+b^2cos^2(x)=c^2sin^2(x)/cos^2(x)
I know I have to quit the sin(x)cos(x) term, how to do it? Please, give me some ideas, I'll thank you a lot.
Other way I've tried is this
we call
x = tan^(-1)(y)
then
ay/sqrt(1+y^2)+b/sqrt(1+y^2)+cy=0
ay+b+cy*sqrt(1+y^2)=0
ay+b=-cy*sqrt(1+y^2)
a^2y^2+2aby+b^2=c^2y^2(1+y^2)
a^2y^2+2aby+b^2=c^2y^2+c^2y^4
c^2y^4+(c^2-a^2)y^2-2aby-b^2=0
The result is a quartic equation where y=tan(x), but this is not the solution I want to get.
Why not try to get all sines onto one side of the equation and cosines onto the other?
How? I still have the sin(x)cos(x) factor.
What's wrong with the quartic?
It's just that this equation can be expressed in this way
This is much more pretty than the quartic.
Other reason is that t's not easy to solve the quartic because of the 2aby factor.
I've reached this equation
(a^2+b^2)-2cb/sin(x)-b^2/sin^2(x)=c^2/cos^2(x)
Don't know next step
I've solved the problem the way you asked me too, I'm not going to step you through it as that ruins the fun...
I basically started from this point though, can you do anything to the right hand side that would cancel a few things on the left hand side?
To use my method you'll have to adapt the sin^2 + cos^2 = 1 equation ever so slightly.
From the point you got to in the quote above there's only 2 lines of working left!
:cool:
Your method may lead to some results too, go down whichever route feels comfortable.
Thanks! I was beginning to believe that it was a wrong method. Now I know it can be solved that way.
And I remember I did something like what you're saying , if you could lend me some more information...
:smile:
For me, it helps to look at the graphs of sin, cos and tan at the beginning of a problem like this, in order to understand what the solution(s) will be, and to understand how to limit the domain of the solution. Maybe just try it briefly to see if it lends some intuition to what you are doing.
Just plot sin, cos and tan over a couple of cycles left and right of the origin, including the asymptotes of the tan function. Do you see some angles where you can get the three to add up to zero, given some A B and C values?
I'm trying to get it this way but I can't reach it. Could you be more specific? What does it mean slightly? Do I have to add 1 to both sides of the equation? Thanks
please help!
I need help!
  • · Replies 21 ·
  • · Replies 19 ·
17K
