How to solve the Klein Gordon Complex Field?
  • Context: Graduate
  • Thread starter Thread starter maverick280857
    Complex Field Klein
The discussion focuses on solving the Klein-Gordon Lagrangian for a complex field, specifically the expression ℒ = ∂μΦ†∂μΦ - m²Φ†Φ. Participants clarify how to differentiate terms involving complex fields and emphasize the independence of a complex field and its conjugate. It is established that real fields correspond to neutral particles, while complex fields represent particles with opposite charges. The significance of treating the field and its conjugate as independent variables is also highlighted, with references to relevant literature for further understanding.
  • Understanding of Classical Field Theory
  • Familiarity with the Klein-Gordon equation
  • Knowledge of complex variables and their derivatives
  • Basic principles of Quantum Field Theory (QFT)
  • Study the derivation of conserved currents in Quantum Field Theory
  • Learn about the implications of complex fields in particle physics
  • Review the independence of fields and their conjugates in Lagrangian mechanics
  • Explore the Klein-Gordon equation in the context of relativistic quantum mechanics
Students and researchers in theoretical physics, particularly those studying Quantum Field Theory, Classical Field Theory, and particle physics. This discussion is beneficial for anyone seeking to deepen their understanding of complex fields and their applications in physics.
  • #31
The point to remember is that a complex field actually has two degrees of freedom: a real part and an imaginary part. Alternatively, we can use a more convenient basis by using linear combinations:
z = x + iy
\bar z = x - iy
and the inverse transformation
x = \frac12 z + \frac12 \bar z
y = -i \frac12 z + i \frac12 \bar z
and so, instead of using x and y, we can just as easily use z and z* as independent variables. This is why we treat phi and its conjugate as independent fields.
  • #32
z = x + iy
\bar z = x - iy
but how do you define the derivative with respect to z*?
  • #33
Like I said, you just treat z and z* as independent variables. You can call them z and w if it makes you feel better. Then just apply the formula
w = z*
as a constraint equation when you're done.Or, here's yet another way you can look at it, using the definitions above:
\frac{\partial}{\partial z} = \frac{\partial x}{\partial z} \frac{\partial}{\partial x} + \frac{\partial y}{\partial z} \frac{\partial}{\partial y} = (\frac12) \frac{\partial}{\partial x} + (-i \frac12) \frac{\partial}{\partial y}
and therefore
\frac{\partial \bar z}{\partial z} = \frac{\partial}{\partial z} (x - iy) = \frac12 \frac{\partial}{\partial x} (x - iy) - i \frac12 \frac{\partial}{\partial y} (x - iy) = \frac12 - i \frac12 (-i) = \frac12 (1 + i^2) = 0
  • #34
w = z*
as a constraint equation when you're done.Or, here's yet another way you can look at it, using the definition z = x + iy:
\frac{\partial}{\partial z} = \frac{\partial x}{\partial z} \frac{\partial}{\partial x} + \frac{\partial y}{\partial z} \frac{\partial}{\partial y} = (1) \frac{\partial}{\partial x} + (-i) \frac{\partial}{\partial y}
and therefore
\frac{\partial \bar z}{\partial z} = \frac{\partial}{\partial z} (x - iy) = \frac{\partial}{\partial x} (x - iy) - i \frac{\partial}{\partial y} (x - iy) = 1 - i (-i) = 1 + i^2 = 0
Okay. One can somewhat define it formally, but it's not a very decent derivative I think. May I ask that what's your opinion on the point I raised in the post #30?
  • #35
sadness said:
Okay. One can somewhat define it formally, but it's not a very decent derivative I think. May I ask that what's your opinion on the point I raised in the post #32?
In what sense is it not "decent"? Note, I forgot some factors of 1/2, went and fixed them.
The first expression you have for the Hamiltonian is correct (with both \pi \partial_t \phi and \pi^* \partial_t \phi^*). Try working the problem in detail to see why.
  • #36
I mean, you can not write the derivative to z* without the help of splitting into x and y. I see your point now. Thanks for pointing out my mistake.
  • #37
Or alternatively, you cannot write a derivative w.r.t. x without splitting into z and z*. It's a matter of using different coordinate systems to represent the same thing.
\frac{\partial}{\partial x} = \frac{\partial z}{\partial x} \frac{\partial}{\partial z} + \frac{\partial \bar z}{\partial x} \frac{\partial}{\partial \bar z}
  • · Replies 24 ·
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 41 ·
