How can I solve this ODE using Bernoulli equation with respect to x?
  • Thread starter Thread starter AdrianZ
    Ode
The discussion focuses on solving the ordinary differential equation (ODE) 2xy'(x-y^2) + y^3 = 0, initially suspected to be a Bernoulli equation. The user attempted to convert it into the Bernoulli form but struggled, exploring parametric approaches instead. They ultimately confirmed that it is indeed a Bernoulli equation and provided a solution method involving substitutions and integrating factors. The final solution is expressed in terms of y and x, demonstrating the successful application of the Bernoulli equation technique. The exchange highlights the importance of recognizing equation types for effective problem-solving in differential equations.
AdrianZ
2xy'(x-y^2)+y^3=0
What kind of an equation is that? I first thought that might be a Bernoulli differential equation with respect to x but I failed to convert it that form. I also checked if the equation could have single variable integrating factors but the answer is negative. How can I solve it?
I would approach it parametrically:
\frac{dy}{dx}=\frac{-y^3}{2x(x-y^2)}
so:
\frac{dy}{dt}=-y^3
\frac{dx}{dt}=2x(x-y^2)
Note the first is de-coupled so solve that one and substitute it into the second one. Maybe though there is something I'm missing and would allow an easier approach.
Thanks for your help jackmell but I already solved it as a Bernoulli equation with respect to x. I'll write down my answer so that it might be useful for someone else.
2xy^' (x-y^2 )+y^3=0
2x(x-y^2 )+y^3 x^'=0
x^'+(2x^2-2xy^2)/y^3 =0
x^'+(-2/y)x=(-2/y^3 ) x^2
so it's a Bernoulli equation and can be solved easily.
-x^{-2}+(2/y) x^{-1}=(2/y^3 )
u=x^{-1}:du/dx=-x^{-2}
{du/dx} {dx/dy}+(2/y)u=(2/y^3 )
du/dy+(2/y)u=(2/y^3 )
μ=e^{∫2dy/y}=y^2
uy^2=∫y^2 (2/y^3 )dy
Ce^{y^2/x}=y^2
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
