In the manufacturing process, (I'm no expert in this part, but I think I have it correct), the material is typically magnetized starting in the molten state above the Curie temperature. It only requires a weak applied magnetic field to get the alignment of the magnetization in one direction. Once that magnetization is established , requiring cooling below the Curie temperature, , it can be very difficult to reverse it, unless you heat the magnet above its Curie temperature. ## \\ ## Meanwhile, toroidal magnets would not have the same type of repulsive or attractive forces properties that you find from cylindrical "pole" magnets. The force in the case of two pole magnets is caused by the gradient in the magnetic field from one, interacting with the magnetization in the other. In the case of a pole magnet in a completely uniform magnetic field, it experiences zero force. In the case of the toroidal magnets, not only is the external magnetic field nearly uniform, it is also nearly zero.
