Undergrad Understanding Admit & Adapt: Timelike Killing Vector Field
  • Thread starter Thread starter GR191511
A space-time is stationary if it admits a timelike Killing vector field, meaning it possesses a vector field that remains constant over time. The discussion clarifies that "admit" refers to the existence of such a vector field, while "adapted to" indicates a coordinate system that aligns with this vector field. In this context, the coordinate system can be chosen such that the Killing vector field takes the form ##X^a=\delta^a_0##, although this is not mandatory. Examples include Schwarzschild coordinates and Kruskal-Szekeres coordinates, which illustrate different adaptations of the Killing vector field.
  • Understanding of timelike Killing vector fields in general relativity
  • Familiarity with stationary spacetimes
  • Knowledge of coordinate systems in differential geometry
  • Basic concepts of Schwarzschild and Kruskal-Szekeres coordinates
  • Study the properties of timelike Killing vector fields in general relativity
  • Explore the implications of stationary spacetimes on physical models
  • Learn about the construction and applications of Schwarzschild coordinates
  • Investigate Kruskal-Szekeres coordinates and their significance in black hole physics
Researchers, physicists, and students in theoretical physics, particularly those focusing on general relativity and the study of spacetime geometries.
GR191511
"A space-time is said to be stationary if and only if it admits a timelike Killing vector field"
"...given a a timelike Killing vector field,then there always exists a coordinate system which is adapted to the Killing vector field##X^a##,that is,in which##X^a=\delta^a_0##holds..."
How to understand "admit"and"adapt"?Does it mean that ##X^a=\delta^a_0## may not hold even if there exists a timelike Killing vector field?Thanks!
Admits, in this context, is a fancy way of saying "has". Stationary spacetimes are those that have a timelike Killing vector field.
"Adapted to" means "well matched to". You can always pick a coordinate system with a timelike basis parallel to the Killing field. It's often a good idea because then your definition of space can be independent of time, and Schwarzschild coordinates are an example of this. But as always with coordinates you are free to make any choice you like. In Kruskal-Szekeres coordinates, for example, the integral curves of the Killing vector field form hyperbolas. You don't even have to have a timelike basis vector if you don't want to.
Likes topsquark, vanhees71, Nugatory and 1 other person
  • · Replies 16 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 21 ·
