How to understand when surface terms go to zero
  • Context: Graduate
  • Thread starter Thread starter Ebarval
    Surface Terms Zero
6 replies · 2K views
Ebarval
TL;DR
When do surface terms go to zero?
Hi all,
I'm trying to understand when surface terms go to zero. I'm not really getting a connection other than many textbooks just saying surface terms go to zero.
I have added a photo of Liboff's Kinetic Theory page 3 on Lagrange's equations. Before equation 1.7, he says the surface terms go to zero because the end points 1 &2 are fixed. But can't the Lagrangian still have a differential with respect to qdot?
PeroK said:
If ##\delta q = 0## then ##\delta q \times X = 0##, whatever ##X## is.
But then why can't that be done on the step after eqn 1.6 or 1.6 itself?
PeroK said:
Because it's not zero everywhere. Only at the end points where the Parts terms are evaluated.
Ah I see! Thank you!
But now I have more questions. How can I tell from integral if something will end up as a surface term and that it goes to zero if there is no such delta term explicitly multiplying?
In this case, ##\delta q## is any variation on the path between two fixed endpoints. That's all there is to it.
How about for the attached section? They mention the surface terms go to zero which I assume are the uk*ul
