How to Write a 2D Array to a .dat File in Fortran90?
  • Context: Fortran
  • Thread starter Thread starter abdulsulo
    2d Array File
The discussion revolves around writing a 2D array to a .dat file using Fortran90. Participants are addressing issues related to subroutine implementation, array passing, and error messages encountered during coding.
  • One participant describes their attempt to write a 2D array to a file and requests help due to errors encountered.
  • Another participant emphasizes the need for error details to provide assistance.
  • A participant shares a specific error message regarding the missing interface for passing an assumed shape array.
  • Some participants suggest creating an interface for the subroutine to properly pass the array.
  • There are discussions about the correct placement of the interface and the use of variable types in the loop.
  • One participant expresses confusion about the structure of the program and the use of the ubound function.
  • Another participant suggests a method to assign the upper bound of an array to an integer variable.
  • A participant raises a question about writing a subroutine that can handle different arrays for output.
  • There is a request for formatting the output to include a comma between two columns in the .dat file.
  • Participants discuss potential issues with variable naming conventions in the code.
Participants generally agree on the need for proper subroutine structure and interface usage, but there are differing views on specific implementations and error handling. The discussion remains unresolved regarding the best approach to pass arrays to subroutines and format output.
Limitations include unresolved issues with variable types, array bounds, and the specific structure of the subroutine. The discussion reflects varying levels of familiarity with Fortran90 among participants.
abdulsulo
Hello everybody,
I have a source code which gives me as a result an array of 2 columns and 3001 rows (2d array). By using fortran90.
I was trying to have the values inside these cells into .dat file and tried to generate a subroutine and call my main array inside this. But somehow I get errors. Linking the code below any help is appreciated.
Fortran:
program hw1
REAL G, Ks, DVIS, EPS,LENGTH,D,Vs,Re,Vi,V0,FFACT,DELt,I,Vi1,J
INTEGER H, T, PHO
real, dimension(3001,2):: VTARR
G=9.81
D=0.3
H=8
ks=0.0001
T=60
DVIS=0.001
PHO=1000
EPS=0.01
DELt=0.02
WRITE (*,*) 'INPUT CYLINDER DIAMETER D:'
READ (*,*) D
WRITE (*,*)'INPUT PIPE LENGTH L'
READ (*,*) LENGTH
    IF (LENGTH==50) THEN
        Vs=6.586        !10.2655
    ELSE IF (LENGTH==100) THEN
        Vs=5.00
    ELSE IF (LENGTH==200) THEN
        Vs=3.669
    ELSE IF (LENGTH==500) THEN
        Vs=2.36
    end if
    Re=PHO*Vs*D/DVIS
    FFACT=0.25/((log10((ks/(3.7*D))+(5.74/Re**0.9)))**2)
    J=1
    do I=0.02,60,0.02
        IF (I==0.02) THEN
        V0=0
        Vi=DELt*H*G/LENGTH
        VTARR(J,1)=Vi
        VTARR(J,2)=I
        J=J+1
        WRITE (*,*) Vi
        ELSE IF (I/=0.02) THEN
        !Re=PHO*Vi*D/DVIS
        !FFACT=0.25/(log((ks/(3.7*D))+(5.74/Re**0.9)))**2
        Vi1=Vi+(DELt*(H-((1+(FFACT*LENGTH/D))*((Vi**2)/(2*G))))*G/LENGTH)
        Vi=Vi1
        VTARR(J,1)=Vi
        VTARR(J,2)=I
        J=J+1
        END IF
        WRITE (*,*) Vi
    end do
    CALL outputdata(VTARR)
PAUSE
    END PROGRAM
SUBROUTINE outputdata(X)
  implicit none
REAL,DOUBLE PRECISION, INTENT(IN) :: X(:,:)
   integer :: i
   ! output data into a file
   open(1, file='data1.dat', status='new')
   do i=1,ubound(X,1)
      write(1,*) x(1,i), X(2,i)
   end do
   close(1)
   ! opening the file for reading
   open (2, file='data1.dat', status='old')
end
<<Moderator's note: code tags added. Next time, you must do that yourself, otherwise your post may be deleted.>>
Technology news on Phys.org
We are not psychics. If you do not tell us what the errors are, we can't help you.
Oh yes Ofcourse. I get this error now:
C:\Users\hasan.dalgic\Documents\Visual Studio 2012\Projects\Console2\Console2\hw1.f90(52): error #7978: Required interface for passing assumed shape array is missing from original source. [VTARR]
You can't pass array X to the subroutine without either passing its size or making an interface for the subroutine:
Fortran:
program hw1
  interface
     subroutine outputdata(x)
        real (kind(1.d0)), intent(in) :: x(:,:)
     end subroutine outputdata
  end interface
Note that you cannot use DOUBLE PRECISION as you did. Also, J should be an integer, as wll as I (you should not have a do loop with a non-integer variable).
Now I modified my code as it is below. But still I get the error:
- A specification statement cannot appear in the executable section.
Fortran:
program hw1
INTEGER H, T, PHO
G=9.81
D=0.3
H=8
ks=0.0001
T=60
DVIS=0.001
PHO=1000
EPS=0.01
DELt=0.02
READ (*,*) D
READ (*,*) LENGTH
        Vs=6.586        !10.2655
        Vs=5.00
        Vs=3.669
        Vs=2.36
    end if
    Re=PHO*Vs*D/DVIS
    J=1
    do I=1,3000,1
        IF (I==0.02) THEN
        V0=0
        Vi=DELt*H*G/LENGTH
        VTARR(J,1)=Vi
        VTARR(J,2)=I
        J=J+1
        WRITE (*,*) Vi
        !Re=PHO*Vi*D/DVIS
        Vi=Vi1
        VTARR(J,1)=Vi
        VTARR(J,2)=I
        J=J+1
        END IF
        WRITE (*,*) Vi
    end do
PAUSE
INTERFACE
    SUBROUTINE outputdata(VTARR)
        real (kind(1.d0)), intent(in) :: VTARR(3000,2)
    END SUBROUTINE outputdata
    END INTERFACE
    END PROGRAM
  implicit none
REAL, INTENT(IN) :: X(:,:)
  INTEGER I
   do I=1,ubound(X,1)
      write(1,*) x(1,I), X(2,I)
   end do
   close(1)
end SUBROUTINE
The interface has to appear right after the program statement, like in the example I posted.
But I find my value to be used inside subroutine at the end of the program. And it will be my variable in subroutine. By the way can I assign ubound(array) into integer variable? I tried it but it was a failure aswell. I am a VBA user and this language is a bit unusual for me.
It should work:
Fortran:
 integer :: i,imax
  imax = ubound(X,1)
  do i=1,imax
  end do
  close(1)
Now the problem is what I get as a result of my main program is VTARR(3001,2) named and dimensioned array.
How can I write a subroutine or a function that sends the values inside this array into .dat file?
Something similar to this but it won' t work as a separated subroutine or function:
Fortran:
imax=UBOUND(VTARR,1)
PAUSE
I=0
   do I=1,imax,1
      write(1,*) VTARR(I,1), VTARR(I,2)
   end do
   close(1)
I don't understand. What you wrote should work. Can you explain better how what you want should be different from that?
Yes it works inside my main program when I write it. But I want to write it outside my main code and use it as a function.
So that I can send various arrays into this function and get the .dat files from each of them.
NOT RELATED TO THİS TOPİC: By the way how can I add "," as a string in between my write(1,*) VTARR(I,1), VTARR(I,2) in order to have format required by datplot program. I need "," in between 2 columns of this array also.
Fortran:
write (1,*) VTARR(I,1), ',', VTARR(I,2)
By the way, you're asking for trouble by using plain 'I' as a variable name. In some fonts, it's very difficult to see typographical errors involving 'I', '1' and 'l'. :mad:
(also 'O' and '0')
26K
12K
13K
