How to write a double summation with separate limits for each variable
alyafey22
MHB
How to write something similar to the following
Or is it better to write
$$\sum_{n=k ,m=1}^{k+1}$$
Try this syntax that produces the following output:
\large \sum_{p^{m} \le x \atop \text{p is prime }m \ge 1 }
$$\large \sum_{p^{m} \le x \atop \text{p is prime }m \ge 1 } $$
The spacing and sizing could use a little work but it's a good start for now.
EDIT: Just found another one on the same page. Try this code as well:
\large \sum_{\substack{p^{m} \le x \\ \text{p is prime }m \ge 1}}
$$\large \sum_{\substack{p^{m} \le x \\ \text{p is prime }m \ge 1}}$$
There is also the subarray environment, which is similar to the regular array environment. It allows aligning the subscripts left or right.
\atop is a plain TeX command.
