- Messages
- 22,170
- Reaction score
- 3,335
reenmachine said:How could nothing intersect with something.
Always go back to the definition. What is the definition of intersection?
Fredrik said:I don't mean to interfere with the discussion, which seems to be going well. Just a little observation: You seem to sometimes be confusing unions with intersections. Intersections give us something smaller, unions something bigger: $$A\cap B\subseteq A\subseteq A\cup B.$$
micromass said:Why not??
What is ##\emptyset \cap A##?? Apply the definition of the intersection.
reenmachine said:Yes it's true , ##\emptyset \cap A = A##
reenmachine said:##\{2\} \cap \{1,2\} = \{2\}## ?
micromass said:There is a very formal definition of intersection and it is as follows:
##x\in A\cap B## if and only if ##x\in A## and ##x\in B##.
If you want, you can also write this in set builder notation:
[tex]A\cap B = \{x\in A~\vert~x\in B\}[/tex]
reenmachine said:Basically , it's unreasonable to think that there would be some common ground for all subsets of ##R## , and therefore this is the empty set.
micromass said:OK, but can you mathematically prove that
[tex]\bigcap_{A\in \mathcal{P}(\mathbb{R})} A = \emptyset[/tex]
Just saying that it's unreasonable doesn't quite cut it.
reenmachine said:I know , I was trying to simplify it to a everyday-conversation level.
Is this a (dis)proof by contradiction?
micromass said:What does it mean by definition that
[tex]x\in \bigcap_{A\in \mathcal{P}(\mathbb{R})}A[/tex]
Right. And if you use the definition of "intersection" to explain what that means...reenmachine said:it means that x is an element of [strike]the set of[/strike] the intersection of all the elements of P(R).
Fredrik said:I'm going to explain this one. I'm going to use spoiler tags so that you won't see the answers until you put your mouse pointer over them. I suggest that you keep thinking about each one for a while before you peek.
$$x\in\bigcap_{A\in\mathcal P(\mathbb R)} A.$$ This set can also be written as ##\bigcap\mathcal P(\mathbb R)## by the way.
Use the definition of the notation:
x is an element of the intersection of all the elements of P(ℝ).
Use the definition of the term "intersection":
x is an element of every element of P(ℝ)
Use the definition of the powerset:
x is an element of every subset of ℝ.
Think of the most useful consequence of that:
x is an element of ∅
Summary and conclusion:
This is impossible. No set is an element of ∅. But the statement above is a logical consequence of the statement that x is an element of the intersection I LaTeXed at the beginning of this post. So that statement must be false.
Since this argument holds for all sets x, we have proved that no set is a member of that intersection. So that intersection must be empty.
I think the simplest way to think here is this: "We're looking for the intersection of all the subsets of ℝ. Since one of those subsets is ∅ and we never get something bigger when we take an intersection, the intersection must be ∅".
reenmachine said:##\emptyset \cap A = A##
You have seen both me and micromass make mistakes in the thread, especially me. It's easy to make mistakes in set theory for some reason. But practice will definitely make you more likely to get through a given problem without a blunder.reenmachine said:In retrospective Fredrik , you might have been right that I sometimes confuse ##\cap## with ##\cup## , it's weird because I clearly know which is which but when I'm in the middle of a thinking process I can confuse them out of nowhere.
My next move is to do some exercises from the bookofproof , I have to work through some problems if I want to stop making stupid mistakes that I shouldn't be doing.
Fredrik said:One post that made me think that you sometimes confuse unions and intersections is #473. You asked (in words) if
$$\bigcap\mathcal P(\mathbb R)=\mathcal P(\mathbb R).$$ This equality wouldn't be correct even if we flip that cap upside down, but I still thought that maybe you were thinking of unions, since you came up with a "big" set instead of a "small" one as the answer.
\begin{align}
\bigcap\mathcal P(\mathbb R) &=\text{intersection of all elements of }\mathcal P(\mathbb R) =\text{intersection of all subsets of }\mathbb R =\varnothing,\\
\bigcup\mathcal P(\mathbb R) &=\text{union of all elements of }\mathcal P(\mathbb R) =\text{union of all subsets of }\mathbb R =\mathbb R.
\end{align}
reenmachine said:Answer: ##\{x \in Z : 2x\}##
reenmachine said:Exercises (from the book of proof section 1.8):
(a)
$$\bigcup_{a \in R}\{a\} × [0,1] = ?$$
Here I'm not sure I understand what they are saying with this notation.Is it (a) × [all numbers between 0 and 1] ?
If that's the case:
Answer: \{R\}
micromass said:This is bad notation.
I read it as: the set of all integers ##x## in ##\mathbb{Z}## such that ##2x## is true.
Clearly, this makes no sense.
reenmachine said:I know the set I'm looking for is the set of all even integers , positive and negative.Don't remember how to write it.
Let me try it again:
##\{x \in Z : \exists y \in Z \ 2y=x\}##
