- 11,959
- 54
Andre, I'll give you a quick and dirty commentary, but just from the abstract, I'd say it is nowhere near ready for publication. Since you've asked, I have no choice than to be blunt, it reads like a freshman lab report, not a scholarly thesis.Andre said:OK Here is the abstract. What would an editor do after reading that?
First, nearly every sentence includes the word "may" or "could," which means it reads as little more than hand-waving. The hypothesis statement is vague and wishy-washy, not to mention hard to find (the first paragraph where you say the hypothesis is contained does not actually contain what appears to be the crux of your hypothesis; it is buried and scattered among several of the later paragraphs). As has already been discussed, it is far too long. Beyond just being long, it rambles on without making any real point. The vast majority is unnecessary filler, and nothing is included to indicate you have any actual evidence or support for your hypothesis that will be discussed within the body of the manuscript. There are grammatical errors as well, but I'm not going to bother with those.
Venus’ planetary "design" (vague)[/color] and its likely[/color] complicated orbit and spinning interactions in the past may have[/color] caused one or more (if you're not sure how many times, how are you sure it happened at all?)[/color] breakouts of the planet’s inner core spinning axis in relation to the spin axis of the mantle. This may have[/color] happened about one billion years ago and may have[/color] had catastrophic results (such as?)[/color]. We intend to demonstrate (how?)[/color] that ]this hypothesis (what part of the above is the hypothesis? It's all "maybe this maybe that," with no testable statement of hypothesis)[/color] may generally explain all enigmatic features (all?)[/color] of Venus simultaneously.
The precession cycles and obliquity cycles of Venus may[/color] have been in a chaotic resonance interaction in the distant past. This may[/color] have caused extreme obliquity changes of the planet’s mantle. Also, precession cycles add up here (where?)[/color] to generate a high rate of change of the spin axis of the mantle of the planet (change of what? rotational velocity? angle? length?)[/color]. The planet’s solid inner core may[/color] not have been stabilized enough to follow these spin axis changes, and its own, individual spin axis may[/color] have departed from alignment with the mantle spin axis. This may[/color] have caused a dramatic braking effect where the spinning energy of the planet was converted to heat, reducing the spinning of the planet significantly. (This paragraph seems to contain more of your hypothesis statement than the introductory paragraph, but still presented too tentatively.)[/color]
(I'm going to stop doing a line-by-line commentary at this point and just hit a few main points...you should get the idea already.)[/color]
The surface of the planet shows several apparent signs of extreme heat, which has been attributed to runaway greenhouse gas effect. It is recognized however, that not all thermal features can be explained either by volcanism or by greenhouse gas effect therefore also radiogenic heating was introduced but there are no further indications for such a aberration from the Earth like composition. An extreme internal heat as caused by the internal braking of the inner core would explain these features far more easily. (But, do you have evidence this IS what happened? Nothing in the abstract suggests you do.)[/color] Also a significant volcanic activity in the early period that diminished gradually as the planet cooled, could also point in this direction.
The atmosphere of Venus contains carbon on about the same order of magnitude as the total Earth lithosphere. This could suggest that all Venus carbon is in its atmosphere, (No, it doesn't. Lack of any carbon in the core and crust would suggest it is all in the atmosphere...if that's true.)[/color] to be explained by a general heating of the complete planet, enough to reduce all limestone type of rocks in the crust to carbon dioxide and calcium oxides. Greenhouse models continue to pose several problems about the current thermal state of the planet. These problems cease to exist however with the notion that the heat is still residual from that the big brake.
Consequently, Venus’ current slow spin state, the extreme heat of the planet and its dense atmosphere, as well as its enigmatic geologic surface features could all be explained by a single mechanism: the big brake.
Most of what is written above does not belong in an abstract. Even without knowing the subject, I can tell you that. In an abstract, state clearly, with only about one to three sentences each: clear statement of hypothesis (1 sentence), approach or method of testing hypothesis (1-2 sentences), most significant results/observations (1-3 sentences), and conclusion (1 sentence).
