How were logarithms calculated before calculators?
  • Level: Undergrad
  • Thread starter Thread starter assuredlonewo
    Logarithms
assuredlonewo
How were logarithms calculated before the use of calculators.
Mathematics news on Phys.org
Here's an iterative method to approximate it. For instance:
Assume you want to calculate logab, where a and b are positive numbers. So you want to find x such that ax = b. From visual inspection, pick a point y so that you're sure that ay < b and a point z so that az > b.
Now consider w = (y+z)/2 (which is the midpoint between y and z). One of three things will happen:
1) aw < b
2) aw > b
3) aw = b
If aw < b, take the midpoint between w and z and repeat. If aw > b, take the midpoint between w and y and repeat. If aw = b, then you're done(though this will probably not happen).
Keep repeating until you're within a certain epsilon of b.
_____
You can also look at the taylor series expansion around a certain point and cut it off past a certain point. This might be more work though.
Before electronic pocket calculators became common, every engineering student owned one of these ...
http://en.wikipedia.org/wiki/Slide_rule
Yes, but you needed to know the value of the logarithms in order to make a slide rule.
I can't speak for what was done historically, but you could use the Taylor's series for the logarithm:
[tex]ln(x)= \sum_{n=1}^\infty \frac{(-1)^{n-1}}{n}(x- 1)^n[/tex]
Ahh!
On "Math Forum- Ask Dr. Math"
http://mathforum.org/library/drmath/view/52469.html
they have
Instead of taking powers of a number close to 1, as had
Napier, Briggs began with log(10) = 1 and then found other logarithms
by taking successive roots. By finding sqrt(10) = 3.162277 for
example, Briggs had log(3.162277) = 0.500000, and from 10^(3/4) =
sqrt(31.62277) = 5.623413 he had log(5.623413) = 0.7500000.
Continuing in this manner, he computed other common logarithms.
Briggs published his tables of logarithms of numbers from 1 to 1000,
each carried out to 14 places of decimals, in 1617.
If you needed more then the 3 digit accuracy of a slide rule you opened a book of log tables. We were even taught to do a linear interpolation to get values between tabulated values.
Halls post is the answer to how did they generate the tables.
Oh, dear! You are showing your age!
Yes that's how we did it in the years "B.C.".
(Before Calculators)
