How would I find the half-reactions?
  • Thread starter Thread starter Bipolarity
The discussion focuses on identifying half-reactions in the redox reaction 2MoS2 + 7O2 → 2MoO3 + 4SO2. Participants clarify that two species are oxidized while one is reduced. The oxidation numbers are crucial for determining which elements are oxidized and reduced, particularly for Molybdenum and Sulfur, which have variable oxidation states. Resources such as Khan Academy and a specific article on oxidation numbers are recommended for further understanding.
  • Understanding of redox reactions
  • Knowledge of oxidation states
  • Familiarity with half-reaction method
  • Basic chemistry concepts related to Molybdenum and Sulfur
  • Learn how to assign oxidation numbers using reliable resources
  • Study the half-reaction method for balancing redox reactions
  • Explore Khan Academy's videos on oxidation states and redox reactions
  • Research the variable oxidation states of Molybdenum and Sulfur
Chemistry students, educators, and anyone interested in mastering redox reactions and oxidation states.
Bipolarity
2MoS_{2} + 7O_{2} \rightarrow 2MoO_{3} + 4SO_{2}
So here I have a redox reaction, it's already balanced but just for kicks I'm trying to find the half-reactions so that I know what is happening. I'm having some trouble though as I don't know what's being oxidized and what's being reduced. Any advice?
Thanks!
BiP
Chemistry news on Phys.org
Two things are oxidized and one is being reduced.
The one that is being reduced should be obvious.
Sorry I don't catch it still. Which one is being oxidized and how do you know?
BiP
Did you try assigning oxidation numbers?
If you're not sure about how to do that, this should help:
http://chemistry.about.com/od/generalchemistry/a/oxidationno.htm
Also, khanacademy.org has some excellent videos (I think three in total) about redox reactions and oxidation states. Start with this one: http://www.khanacademy.org/video/introduction-to-oxidation-states?topic=chemistry and work your way through the next few.
I also recently asked a question about balancing by half-reaction method here, and got some good help which may in turn help you: https://www.physicsforums.com/showthread.php?t=578120
The problem is both Molybdenum and Sulphur have variable oxidation numbers so I don't know what they are.
BiP
Polysulfides are a little bit tricky. In general they have a form Sn2-. For S22- you can safely assume both sulfur atoms are identical and each has an oxidation number of -1. This is analogous to hydrogen peroxide where both oxygen atoms are assigned ON of -1.
  • · Replies 16 ·
