Balancing Redox Reaction by Half Reaction Method
The discussion revolves around balancing a redox reaction using the half-reaction method, specifically focusing on the reaction between copper(II) chloride and aluminum. Participants explore the challenges of balancing the reaction, particularly concerning the role of spectator ions and the correct application of half-reactions.
  • Homework-related
  • One participant expresses confusion about balancing the reaction involving compounds and seeks guidance on the half-reaction method.
  • The participant attempts to identify oxidation and reduction half-reactions but is uncertain about the treatment of chlorine in the reaction.
  • Another participant clarifies that Cl- is a spectator ion and suggests that the participant should split the reduction into two parts.
  • A follow-up question is raised regarding the reasoning behind Cl- being a spectator ion, specifically whether it is due to its unchanged charge throughout the reaction.
  • Further confirmation is provided that Cl- does not participate in the reaction, supporting its classification as a spectator ion.
Participants generally agree on the role of Cl- as a spectator ion, but the discussion remains unresolved regarding the participant's initial confusion about the half-reaction method and the specifics of balancing the equation.
The discussion highlights limitations in understanding the half-reaction method and the role of spectator ions, with some assumptions about the participant's prior knowledge of these concepts. There are unresolved aspects regarding the correct approach to balancing the reaction using half-reactions.
moouers
CuCl2(aq)+Al(s)→AlCl3(aq)+Cu(s)
I'm just not sure what to do with a situation involving compounds. I can do simple balancing without a problem. Here is my attempt. Please, please let me know where I went wrong...
Oxidation: Al→Al+3+3e-
Reduction: Cu+2+2e-→Cu
Reduction: 2Cl-2→3Cl-3 (?)
I'm confuzzled. I don't know where to go from here, or even if I did the above correctly. The book is pretty awful in describing these half-reaction equations, so I've been searching online but without any applicable results. I didn't think I should split the reduction into two parts, but maybe I do. I don't know. I also don't know what to do with the equation concerning the Chlorine. All around, I'm confused.
I can balance the equation just fine with the "trial and error" method, and it matches the back of the book, I just don't know how to get there by half-reactions.
Thank you so much for any help.
Cl- is just a spectator and doesn't change during the reaction. Yes, you should split.
Check ChemBuddy page on the half reaction method. If it doesn't help, ask for clarification (here or there).
Well, gee. That was simple! Thank you very much, and thank you for the link. I suppose what got me then was my assumption that I understood spectator ions pretty well. I guess not! In this case, is Cl- a spectator because we don't need to balance the charge since it stays the same throughout the reaction?
It is a spectator because it doesn't take part in the reaction. It doesn't take part in the reaction - so it doesn't change its charge.
Got it. Thanks.
  • · Replies 18 ·
