How would one read website content using a program?
The discussion revolves around methods for coding a program to read and extract textual content from websites. Participants explore various programming languages and tools, including PowerShell, Python, PHP, and VB.NET, to achieve web scraping and data extraction based on specific keywords.
  • Homework-related
  • One participant seeks guidance on coding a program to read website content and trigger commands based on keyword detection.
  • Another suggests using VB.NET's WebRequest for similar functionality, indicating that many modern languages have comparable features.
  • Some participants mention using the curl command in Linux/macOS for fetching web pages, followed by data extraction using languages like awk, perl, python, or ruby.
  • A PowerShell script is shared, but the original poster encounters issues with its execution and seeks troubleshooting advice.
  • Python is highlighted as a popular choice for web scraping, with modules like requests and BeautifulSoup recommended for handling web content.
  • Participants emphasize the importance of adhering to a website's robots.txt file when deploying web scrapers to avoid potential blacklisting.
  • PHP is discussed as a straightforward option for web scraping, with functions like file_get_contents and cURL mentioned for retrieving web page content.
  • Multiple string manipulation functions in PHP are outlined for searching content within retrieved web pages, with suggestions for rewriting the original PowerShell code in PHP.
  • One participant expresses confusion about integrating PHP code with PowerShell scripts, leading to a discussion about the differences in syntax and error handling between the two languages.
Participants present various methods and tools for web scraping, with no consensus on a single best approach. Disagreements arise regarding the integration of different programming languages and the specific implementations of web scraping techniques.
Limitations include potential misunderstandings of programming syntax across different languages, as well as the need for familiarity with HTML structure to effectively extract desired data. The discussion also reflects varying levels of expertise among participants.
This discussion may be useful for individuals interested in web scraping, programming in PowerShell, Python, PHP, or VB.NET, and those looking to automate data extraction from websites.
jackparker5
I'm basically looking to find out how I could code a program to read the textual contents of a website (in either batch, dev c++ or powershell script - or a combination) and then search for a specific word, which when found, will trigger a set of commands. It's basically like the findstr command in batch, that can look through local text files.
Technology news on Phys.org
Some folks use the curl command in linux/macos to get a webpage and the use awk, perl, python or ruby to extract out the data of interest. program
https://en.wikipedia.org/wiki/CURL
There is also a library of APIs that can be used in a C program for example.
It's meant to search for the URLs mentioned in urls.txt and as you can see, search for the word "Test" in the content of the URL, this is the code so far:
$webClient = new-object System.Net.WebClient
$webClient.Headers.Add("user-agent", "PowerShell Script")
$info = get-content c:\users\dell\desktop\urls.txt
foreach ($i in $info) {
$output = ""
$startTime = get-date
$output = $webClient.DownloadString($i)
$endTime = get-date
if ($output -like "Test") {
"Success`t`t" + $i + "`t`t" + ($endTime - $startTime).TotalSeconds + " seconds"
But for some reason, it won't work. Does anyone have a suggestion as to why not?
In python there are 2 modules like
Python:
import requests; from bs4 import BeautifulSoup
They allow you to request, process and parser information from a url. Though you should know some information of the url's source code (html) to be able and get the data you like, with my chrome browser I just right click on the site's page and ask to view the page source.
By the time you retrieve the data, you can process them in the same script as if you had Inputed it from a text-like file from your local PC (eg output them, use them as variables or for logical expressions and stuff).
The keywords you need seem to be web scraping.
As far as I can tell Python is used most often. There likely are some very explicit tutorials that do this.
If and when you deploy such a scraper I would urge you to comply with the robots.txt file if provided by the website.
That file will tell you if you're "allowed" to scrape the website. Otherwise you might be blacklisted by some sites depending on the traffic you generate.
With PHP, this can be really easy with a simple file_get_contents:
PHP:
$pageSource = file_get_contents('[PLAIN]http://www.example.com/');
[/PLAIN]
And $pageSource is a string containing the source code of the web page!
If you want to do more, then there is the cURL library. This is basically a web browser (really, if done properly, a web host won't know if it's a human or cURL requesting the web page). You can set the header sent and read the header received. So you can POST (i.e. fill in forms and sending them), use cookies, read over secure protocol (HTTPS), upload files ... and so much more.
I'm used with the PHP version, but cURL is available as a free command-online tool (Tutorial, How to Use, curl usage explained) and libcurl is also available for C (and probably others as well). The cURL website even offer a comparison table with their competitors, if you want to explore more options.
PHP:
[/PLAIN]
Thanks, that seems quite easy. Do you know how I could search the variable $pageSource for a list of words? Does it need to be printed somewhere, or can it be done directly? I'm not good with PHP at all, and that would be an overstatement.
To manipulate strings in PHP, you have the string functions and the regular expression functions. For simply searching, you can use:
  • stripos — Find the position of the first occurrence of a case-insensitive substring in a string
  • stristr — Case-insensitive strstr
  • strpbrk — Search a string for any of a set of characters
  • strpos — Find the position of the first occurrence of a substring in a string
  • strrchr — Find the last occurrence of a character in a string
  • strripos — Find the position of the last occurrence of a case-insensitive substring in a string
  • strrpos — Find the position of the last occurrence of a substring in a string
  • strstr — Find the first occurrence of a string
  • substr — Return part of a string
Rewriting you code in PHP could simply be:
PHP:
// Assuming one URL per line in file:
$info = file("c:\users\dell\desktop\urls.txt");
foreach ($info as $url) {
    $output = "";
    $startTime = microtime(true);
    $output = file_get_contents($url);
    $endTime = microtime(true);
    if (strpos($output, "Test") !== false) {
        // I'm not sure if «`t`t» is a special syntax I'm not familiar with
        // or if you want to write it literally, I assume the latter
        echo "Success`t`t" . $url . "`t`t" . ($endTime - $startTime) . " seconds";
PHP:
    $output = "";
Well what I had as code was PowerShell Script (.ps1) I'm not sure how PHP code can be put together with it, can it? I tried to run the code you wrote in PowerShell Script ISE and it said:
Missing 'in' after variable in foreach loop.
At line:4 char:16
Sorry for my lack of knowledge..
A slight difference as you can read about here http://ss64.com/ps/foreach.html
When encountering such an error you can google using "Powershell" + "Missing 'in' after variable in foreach loop"
Or if you don't know the construct you are using use "Powershell foreach" which gave the link above for me.
First, I must apologize as I didn't notice your code on my first post, hence why I brought PHP as I thought you were looking for a more general method. And PHP is not powershell, so it won't work with that.
Got to work with PS and I think I found your mistake. I just checked the part about fetching a URL and looking for a word:
Code:
    $output = ""
    $endTime = get-date
    if ($output -like "*Test*") {
        $time = New-TimeSpan $startTime $endTime
        Write-Host "Success`t`t" $i "`t`t"  $time.TotalSeconds " seconds"
The "*" before and after "Test" means match anything before and after "Test". I also add a "Write-Host" command before your string to write it on screen and the "+" signs aren't necessary to concatenate the strings. As I suspected "`t" is a tab. And I introduced the TimeSpan command.
Or you could use the regular expression version (apparently it is faster):
Code:
    $output = ""
    $endTime = get-date
    if ($output -match "Test") {
The code you provided worked fine : ) Thank you
For non-text materials such as online documents such as .pdf or .doc, how do you read the contents?
You have to download the file and open it with a program that can read such contents.
I mean using a program so it can be automated?
Same answer. For example, when you open a .pdf in your browser, your browser must have an access to a program that can read .pdf files if it wants to show its contents. The browser just download the file. If it doesn't have such an access, it will show you a 'Save as ...' window.
  • · Replies 32 ·
  • Sticky
9K
  • · Replies 17 ·
  • · Replies 75 ·
