Hwk Problem: Mechanical Energy
The discussion focuses on calculating the change in mechanical energy and the average force exerted by a wall on a bullet. For part (a), the change in mechanical energy is determined using the kinetic energy formula, recognizing that potential energy remains constant since height does not change. For part (b), the average force can be calculated by relating the change in kinetic energy to the distance traveled using the formula: change in kinetic energy equals force times distance. Participants confirm the approach and calculations, leading to correct answers. The thread concludes with a user expressing satisfaction with their results.
shawonna23
A 30 g bullet, with a horizontal velocity of 516 m/s, stops 19 cm within a solid wall.
(a) What is the change in its mechanical energy?
(b) What is the magnitude of the average force from the wall stopping it?
For Part a, To find the change in mechanical energy, do I use the equation: ME=(1/2)mv^2 + mgh
For Part b, I can use this equation F=m*a
a. yes
b. yes
ME = (1/2)mv^2 + mgh
(1/2)(mass)(velocity squared) + (mass)(gravity)(height)
F = m*a
Force = mass * acceleration
use this to solve your problems
For a) You should use conservation of energy. i think you can assume that the height of the bullet remains the same, so there is no change in potential energy mgh. basically the clue is that you come in with velocity 516 m/s and you stop after 0.19 m.
The change in mechanical energy is calculated by realizing that the kinetic energy goes from 1/2mv² to 0
For b) assume all horizontal motions. You can calculate the force that makes the object stop from this equation : change in kinetic energy = traveled distance * Force
So you'd have 1/2*30*516² = 0.19 * F...Solve for F
marlon
Thanks guys, I got the answers and they were correct!
  • · Replies 22 ·
