HX711 query (Amp/ADC for load cells)
  • Thread starter Thread starter volican
    Cells Load
The HX711 ADC requires specific input voltage levels based on the selected gain settings. For a gain of 128, the differential input voltage must be within ±20mV when powered by a 5V supply. The input configuration for Channel A must adhere to this range to avoid clipping or damage. Additionally, the gain options are limited to 128 or 64 for Channel A, while Channel B has a fixed gain of 32. Using a 3V supply will alter the input voltage range and should be considered in the design.
  • Understanding of HX711 ADC specifications
  • Knowledge of differential input voltage concepts
  • Familiarity with Wheatstone bridge configurations
  • Basic electronics principles regarding voltage and gain
  • Review the HX711 datasheet for detailed specifications and electrical characteristics
  • Experiment with differential voltage inputs using the HX711 at various gain settings
  • Learn about the implications of using different supply voltages on ADC performance
  • Investigate the design and calibration of strain gauges in Wheatstone bridge circuits
Electronics engineers, hobbyists working with load cells, and anyone involved in precision measurement systems utilizing the HX711 ADC.
volican
For the HX711 (data sheet here) I am a bit confused by what it expects as the input voltages. I think its this bit that is relevant:
"Channel A can be programmed with a gain of 128 or 64, corresponding to a full-scale differential input voltage of ±20mV or ±40mV respectively, when a 5V supply is connected to AVDD analog power supply pin. Channel B has a fixed gain of 32."
Does that mean that if I want a gain of 128 the +ve must be +20mv and the -ve must be -20mv? What If I am using strain gauges in a Wheatstone bridge that will change? FYI for my project I plan to use a 3V button cell. What impact will that have? Just to confirm when they say gain do they mean that my output will be (+ve)-(-ve)*128?
Thank you very much for your help :)
The first of the "Key Electrical Characteristics", the full scale differential input range, needs to be followed. If exceeded, clipping of the input signal or physical damage could occur.
According to this line of the datasheet, for AVDD of 5 V and gain of 128, this results in +/- 20 mV. Take the +20 mV case for example, this is described as being equal to "V(inp) - V(inn)". This puts V(inp) at 10 mV and V(inn) at -10 mV.
You can experiment with this device by applying this differential voltage (with AVDD = 5 V and gain = 128) and verify that you indeed get a full scale ADC result.
Thanks. Do the gain values have to stay as 128 or 64 or can they be a wide range of values. Could I just rearrange that formula to find what the gain will be? Does the HX711 work like that or is it saying that the gain can only be 128 or 64 and this is a limitation that the rest of the circuit will have to accommodate?
Many thanks for your help, that really helped me out. Was staring at it for hours.
Looks like the gain on channel A can only be 128 or 64. Page 5 of the referenced datasheet shows how to do this.
Thanks a lot. Really appreciated.
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
10K
