Hy does every action have an equal and opposite reaction?
  • Context: High School
  • Thread starter Thread starter anand
    Reaction
The discussion centers on the principle that every action has an equal and opposite reaction, rooted in Newton's third law of motion and the conservation of momentum. Participants highlight the importance of experimental consistency and the role of entropy in observing physical phenomena. The conversation also references Noether's theorem, which connects conservation laws to symmetries in physics, specifically spatial translation symmetry. The consensus is that while the laws of physics appear invariant across locations, the underlying reasons remain uncertain.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of conservation of momentum
  • Basic knowledge of Noether's theorem
  • Awareness of experimental design and the effects of entropy
  • Study Newton's laws of motion in detail
  • Explore the implications of conservation of momentum in various physical systems
  • Investigate Noether's theorem and its applications in physics
  • Examine the role of entropy in experimental physics
Students of physics, educators, and anyone interested in the foundational principles of mechanics and the nature of physical laws.
anand
Why does every action have an equal and opposite reaction?
Because the Lagrangian of mechanical processes is invariant under translations.
Heh heh.Actually I am a high school student.So, I don't really understand what you mean.Could you please explain?Any way,thanks for replying.
This was a completely inapproiate response to a students question. I will not tolerate such garbage here.
Integral
Thats a tough question because it is something that seems (to me at least) to be self evident: It just does. So let me turn it around - is there something that leads you to believe it wouldn't?
The best reason I can come up with is because it does. This is an observation of Newtons and is incorporated in his fundamental laws. The goal of physics is to make predictions based upon observations. This is the observation. We cannot discuss why, it simply is.
i know it sounds totally nuts but maybe it was because somebody told Newton to say so
but was aplied in the wrong context
There exists a casual geometrical explanation of action, reaction and theit subsequent resultant(s).
Rybo
Where you repeat experiments in the 'exact' manner, results show no deviaition from observed effects, you do something and something happens as a result, technically you cannot repeat any 'event' in exactly the same 100% way, Entropy will force you to comply to its natural path!
Now what is interesting is if you get a different angle on the possible number of ways you can do 'exact' experiments?.
For instance let's say Galilleo performs an experiment on the leaning tower of pisa, he drops a cannonball, it falls to Earth. If he goes back up and does the experiment again, he could deduce the time taken for the cannonball to drop to the ground, and make some basic assumptions based on the experiment.
Now if Galilleo, instead of retrieving the cannonball and goes back up the tower, he digs a hole into the ground next to the cannonball to a similar height of the Pisa Tower, and then drops the cannonball into the hole whilst peering over the edge taking notes, this a variation on the effects of Gravity, the original setup has changed, so the observed effect alters in a small way to compensate for difference's.
This experiment differs from the original, although the effect of the falling cannonball is governed by the same force, the slight difference in experimental setup, produces a differing 'observed' effect.
So every SIMILAR ACTION has a SIMILAR REACTION which is dependent on the exactness of the environmental setup. Most of Earths environment is similar to us, but differs vastly to that of say a dynamical Jupiter.
We are confined to our limited, but satisfactionary observations of a wider dynamical Universe and its constraining governing Effects.
Originally posted by Ambitwistor
Specifically, every force has an equal and opposite force. This is because of conservation of momentum. Force is a change in momentum over time. If momentum is conserved, then it cannot change with time. That means that if you apply a force to change the momentum of part of a system, there must be an opposing change in momentum (force) to keep the total change in momentum equal to zero.
So, your question has been reduced to the question, "Why is momentum conserved?" If you study the Lagrangian formulation of mechanics, you learn that conservation laws are due to symmetries. (This is known as "Noether's theorem".) In this case, the law of conservation of momentum is due to a spatial translation symmetry. In plain terms, the outcome of an experiment should not depend on where it is performed. So if you move from one place to another ("translation in space"), the laws of physics are unchanged ("the laws of physics are invariant under spatial translation"). Noether's theorem says that there must then be a conserved quantity, which we call "momentum".
So, your question has been further reduced to the question, "Why are the laws of physics the same at all locations?" We don't know. Maybe they aren't ... they are as far as we know, but we can't know for sure.
This is has been the best formal anwer yet.
"Conservation of momentum" sounds much like "conservation of energy." I would informally extrapolate from those statements a "conservation of inerta" as well.
Why these three and others are conserved is due to the physical Universe being a finite integral whole.
Why are the laws of Universe the same everywhere in Universe as far as we know?
Beacuse if they weren't the integrity of our physically finite whole of Universe would not exist.
Rybo
That isn't true for static forces as there is no momentum or energy change.
Integral really said it best: it is observed to be true.
10K
  • · Replies 49 ·
  • · Replies 56 ·
