Designing & Pricing a Hydraulic System - Help for College Project
  • Thread starter Thread starter smear
    Hydraulic System
The discussion focuses on designing and pricing a hydraulic system for a college project, specifically requiring a 10 kW motor, four cylinders with an 80mm bore and 30mm rod diameter, and essential components like a 4/3 directional control valve, check valve, and non-return valve. Key specifications for the control valve include defining minimum, normal, and maximum values for flow rate, inlet pressure, and outlet pressure to determine the Cv sizing. Additionally, the piping size should be selected to achieve a fluid velocity between 3 to 8 ft/sec.
  • Understanding of hydraulic system components, including motors and cylinders.
  • Knowledge of control valve specifications and sizing.
  • Familiarity with fluid dynamics and flow rate calculations.
  • Basic principles of piping design for hydraulic systems.
  • Research control valve Cv sizing techniques for hydraulic systems.
  • Learn about fluid velocity calculations and their impact on piping design.
  • Investigate suppliers for hydraulic components and pricing strategies.
  • Explore hydraulic system design software tools for simulation and analysis.
Engineering students, hydraulic system designers, and professionals involved in fluid mechanics and system optimization will benefit from this discussion.
smear
Hi, I am doing a project in college and i need to get a hydraulic system designed and priced. I have a good understanding of what I required for the sytem, A 10 kw motor, four 80mm diameter bore and 30 mm rod diameter cylinders, a 4/3 directional control valve a check valve and a non return valve. Just wondering if some one could point me in the right direction in relation to what else I would require to define the specification for the control valve and the type/size of piping required and what else may be required.
Also if some could put me in contact with a company that would be able to do up a pricing on it I would greatly appreciate it as I am having difficulty getting on to companies.
Cheers,
Smear!
You will need to define your minimum, normal, and maximum values for flow rate, inlet pressure, and outlet pressure to size the Cv for control valves. Pair these values so the control valve is excercised over the entire range. Shoot for about 50% open at normal conditions, less than 80% open for max, and more than 20% open for min.
The type of piping will depend on the fluid and flows. To start, pick pipe sizes to give you between 3 to 8 ft/sec velocity.
  • · Replies 18 ·
  • · Replies 19 ·
