Hydro-electric Dam Penstock Analysis
  • Thread starter Thread starter jamesm
    Analysis
The discussion focuses on determining the minimum thickness required for exposed steel penstocks in hydro-electric dams, specifically addressing the challenges of calculating internal pressure increases due to water hammer. It is established that controlling the flow rate through slow adjustments mitigates the impact of water hammer. Additionally, matching the impedance of the penstock to the turbine minimizes energy reflection, while surge towers, although sometimes utilized, have minimal effect on water hammer dynamics.
  • Understanding of water hammer effects in fluid dynamics
  • Knowledge of penstock design and materials
  • Familiarity with impedance matching in hydraulic systems
  • Experience with operational procedures for flow rate adjustments
  • Research methods for calculating water hammer pressure in penstocks
  • Learn about materials and thickness standards for steel penstocks
  • Explore impedance matching techniques for hydraulic systems
  • Investigate the role and design of surge towers in hydro-electric systems
Hydraulic engineers, civil engineers, and project managers involved in hydro-electric dam design and maintenance will benefit from this discussion.
jamesm
I am currently working on a project where I need to determine the minimum thickness required in some exposed steel penstocks. It seems to be a straight forward project, however I have been having trouble finding information on calculating the internal pressure increase due to water hammer in the penstocks. If anybody has any experience with this I would appreciate your thoughts. Thank you.
Water hammer in the penstock is critical, but it should not be big problem if the operation of the system is controlled by slow adjustment of the flow rate. Operational procedure will decide the maximum water hammer that will be encountered.
If you can match the impedance of the transmission line, (=penstock), to the turbine, then there should be little energy reflected from the turbine or control gate.
Surge towers are sometimes used at the top of the penstock where the vertical section of the penstock is fed by a horizontal pipeline, but surge towers have little effect on water hammer.
9K
  • · Replies 29 ·
