Hydrogen Atom's Energy Levels-True/False
  • Thread starter Thread starter sona1177
    Energy Hydrogen
14 replies · 10K views · last reply
sona1177
Which of the following statements are true about the hydrogen atom's energy levels?
the ground state (n = 1) energy is -13.6 eV TRUE
the wavelength of a photon emitted from the n=3 to n=2 transition is longer than that emitted for the n=4 to n=3 transition FALSE
13.6 eV is enough energy to ionize hydrogen, which means exciting an electron from n = 1 up to zero energy TRUE
the hydrogen atom in its ground state can absorb a photon of any energy less than 13.6 eV FALSE
the hydrogen atom in its ground state cannot absorb a photon of any energy greater than 13.6 eV
TRUE
WHAT AM I DOING WRONG??
"What am I doing wrong" is a fairly vague question...
I realize that, but since its true and false, I don't know how else to ask.
So you're asking if what you have is right or wrong?
Well I know at least one of the answers is wrong because I am getting marked incorrect.
Im thinking the third and last one are both false. Because if n>1 then that would be an excited state. is this right? thanks!
would all of them be false except the first one? because if its in the excited state then n>1 and then E >13.6eV? I know the first and second ones are correct for sure :)
If you're talking about n>1 for the 2nd problem, it's not really what's being asked. Both transitions are acceptable and they will emit a photon. However they'll be different energy photons and it's basically asking which will have a larger wavelength (and you picked correctly). The last question I believe is wrong. I'm pretty sure you can just have a scattering action from the extra energy but I'm not certain.
Actually don't take my word on this stuff, it's been a while since I've done NR QM...
Sorry I don't think I am thinking straight here.
If En=E1/n^2 where E1=-13.6 eV and n=1,2,3, then wouldn't E always be less than E1, then the fourth statement is true and the last is also true. so I would have:
the hydrogen atom in its ground state can absorb a photon of any energy less than 13.6 eV TRUE
TRUE
IS this correct?
well i found out the last two are true. but its still marking me wrong when i have
True
false
true
true
true
Could the third one be wrong?
Statement - the hydrogen atom in its ground state cannot absorb a photon of any energy greater than 13.6 eV.
It is FALSE.
because it can absorb a photon of greater energy, be ionized and the extra energy is converted to kinetic energy of the electron.
It is FALSE.
SO IS IT GOING TO BE:
FALSE
Statement - the hydrogen atom in its ground state can absorb a photon of any energy less than 13.6 eV
is FALSE.
it can only absorb discrete energies less than 13.6ev, which correspond to energy difference between level 1 and some upper level.
THANKS, SUPRATIM. LET ME TRY AGAIN (I AM SUBMITTING THIS FOR HOMEWORK AND IM ON MY LAST TRY SO IF I GET THIS WRONG, I WILL LOSE ALL THE POINTS, SO I WANT TO DOUBLE CHECK):
FALSE
welcome Sona. yes you are right now. all the best for your homework, you will surely get full marks. :-)
Thanks, Supratim! I got this one right. Now onto the other Rutherford one . . .
