Hydrogen Fusion Engine: Steel Sphere & Sulfuric Acid
The discussion centers on the feasibility of using a thick steel hollow sphere filled with sulfuric acid and water to create a hydrogen fusion engine. Participants clarify that according to Gauss's law, a charged hollow sphere generates no electric field inside, meaning that hydrogen ions cannot be attracted or repelled within the sphere. The mathematical principles supporting this conclusion are well-established and referenced, indicating that the proposed method for hydrogen ion acceleration and fusion is fundamentally flawed.
  • Understanding of Gauss's Law in electrostatics
  • Knowledge of electric fields and forces within charged conductors
  • Familiarity with hydrogen fusion processes
  • Basic principles of chemistry related to sulfuric acid and water interactions
  • Study Gauss's Law and its applications in electrostatics
  • Research the principles of hydrogen fusion and the conditions required for it
  • Explore the chemistry of sulfuric acid and its behavior in electrochemical processes
  • Investigate alternative methods for achieving hydrogen ion acceleration in fusion experiments
Physicists, chemists, and engineers interested in electrostatics, fusion technology, and the chemical properties of sulfuric acid. This discussion is particularly relevant for those exploring theoretical approaches to hydrogen fusion engines.
Bruce Haawkins
Have a thick steel hollow sphere with a inside radius of 20 cm. Then fill it up with sulfuric acid and add water. Then remove the oxygen ions. then give the sphere a negative charge and all the hydrogen ions move to the surface of the inside sphere. then charge sphere positive and the hydrogen ions accelerate towards the center of the sphere and fuse.
Apart form other more specific reasons, EM (gauss law) tells you that a charged hollow sphere has no electric field inside. So you won't be able to neither attract or repel H ions.
Posted has been reminded to maintain a civil attitude in posts
Please do the maths before you speak the charged particle has not gotten an even amount of cancelling forces on it. The forces only cancel right at the center of the sphere.
This is incorrect. As @dRic2 says, the electric field from a charged sphere is zero inside, and hence the force on a charge inside the sphere is zero. This is a standard result, the maths for which was done by Gauss over two centuries ago. See, for example, Wikipedia.
Wikipedia said:
We can use Gauss's law to find the magnitude of the resultant electric field E at a distance r from the center of the charged shell. It is immediately apparent that for a spherical Gaussian surface of radius r < R the enclosed charge is zero: hence the net flux is zero and the magnitude of the electric field on the Gaussian surface is also 0
In addition to the other problems.
How, exactly?
How much exactly?
Because the thread is based on a misconception, it is now closed.
13K
  • · Replies 19 ·
