Hydrostatic force on triangular tank end and work to pump it out
  • Thread starter leo255
    Force Tank
5 replies · 2K views · last reply
leo255
[/B]
You are given a triangular trough (base of triangle on top) that is 15 feet long, 2 feet wide, and 3 feet tall.
a. Find the force of the water on one triangular end.
b. Find the work required to pump all the water over the top.
Just a note: This was question that I got wrong on a previous exam. I am doing it over now to study for the final, and don't know the answer, so my work could be correct or incorrect. Please feel free to be critical of any mistakes/errors that I make. I try to explain my reasoning in my attempt at the solution.
Water weighs 62.4 lb/ft^3.
For a: I believe I will need area * depth * water weight (62.4 lb/ft^3)
The height is 3 feet, so I made the height of wi to be (3-y). To get the width of wi, I used similar triangles, and ended up with 3 - 2y/3. So, I have the depth (3-y) * the area of wi (3 - 2y/3 dy) * the water weight (62.4).
I integrated from 0 to 3 of 62.4 (3 - y)(3 - 2y/3) dy.
For b:
I feel I can use the above integral, and add to it (the area of the thin strip will still be wi * 3-y * the water weight. Since we're using the entire tank, I need to use the 15 feet length, and since this is work required to empty the tank, I feel that I will need to introduce the gravitational constant (9.8 m/s^2).
So, I integrate, from 0 to 3, of 15 * 9.8 * 62.4 * (3-2y/3)(3-y) dy
= 9172.8 * the integral, from 0 to 3, of (3 - 2y/3)(3-y) dy
leo255 said:
[/B]
But what's your final answer?
For b:
You can't use 9.8 m/s2 here. Why?
Using a calculator, I got 656.25 lbs of total force for A. Yeah, you can't use meters because the triangle is measured in feet - that was a dumb mistake. Would I just replace that with 32.15 ft/sec^2?
Using that for B, I would get approximately 316,476.56. Not sure exactly which unit of measure to use for this.
That's OK. g is usually taken as 32.2 ft/s2 in the imperial units.
If you are calculating work, then you must have units for work (force * distance, eh?)
Going back to your derivation of the hydrostatic force, you used the depth as (3 - y) and the width wi as (3 - 2y/3). When y = 3 feet, the depth is zero, but wi must be 2 feet, the width of the trough at the top. Similarly, when y = 0, wi must be zero, since we are at the bottom of the trough.
Would it work if I made it (6 - y) instead?
You can answer that question yourself. Try drawing a sketch of the end of the trough.
