Hydrostatic Force Problem - Calculus
The discussion centers on calculating the hydrostatic force on the vertical side of a tank shaped by the curves y=2x² and y=8, assuming the tank is full of water. The formula used is F=pgAd, where p is the water density (1000 kg/m³), g is gravity (9.8 m/s²), A is the area, and d is the depth. The integral set up for the calculation is ∫(1000)(9.8)(8-2x²)(2x)dx, evaluated from 0 to 2, with the final result being 313600 N. The user expresses uncertainty about the correctness of their calculations and seeks assistance.
  • Understanding of hydrostatic pressure principles
  • Knowledge of calculus, specifically integration techniques
  • Familiarity with the concept of definite integrals
  • Basic understanding of the physical properties of water
  • Review the derivation of the hydrostatic force formula F=pgAd
  • Study integration techniques for calculating areas under curves
  • Learn about the application of definite integrals in physics problems
  • Explore examples of hydrostatic force calculations in various tank shapes
Students studying calculus, physics enthusiasts, and anyone involved in engineering or fluid mechanics who needs to understand hydrostatic force calculations.
HanRam
Find hydrostatic force on the vertical side of the tank that has the shape of the region bounded by the curves y=2x2, y=8. Assume that the tank is full of water.
F=pgAd (force = density*gravity*area*depth)
I know I need to set up and evaluate an integral, and I believe it must be evaluated from 0 to 8, since the top of the tank is at y=8. Other than this though, I have been unable to set up the integral that I need. Any help as to how the integral would be set up would be appreciated.
After hours working at this problem, I think I may have figured it out, but I'm not at all sure that I did it correctly. Anyway, here is what I came up with.
[tex]\int(1000)(9.8)(8-2x^2)(2x)dx[/tex]
After calculating this integral from 0 to 2 (I did this because x=0 corresponds to the bottom, and x=2 corresponds to the top), I multiplied my result by 2 to compensate for the fact that I was only integrating for the right side (0 to 2), and by multiplying by 2, that would cover the left side (-2 to 0).
My final result was 313600 N. Can anybody tell me if I went wrong somewhere? (Which I have a feeling I did).
You know anything about calculating hydrostatic force? Wanna help me calculate hydrostatic force here? No? I could use a little help. I need a little assistance. I never took a calculus class, and I need a little help. Ok, I'm just coming flat out and saying 'help me'. Anybody want to help a semi-retarded individual calculate hydrostatic force? 25, 30 dollars. 30 dollars to calculate hydrostatic force. 35 dollars to calculate hydrostatic force right now.
I'll give you 10 dollars for a typed response. 10 dollars. Anybody want to make 10 dollars and respond virtually? No?
