Hyperbolic sine in Taylor Series
The discussion focuses on the Taylor series expansion of the hyperbolic sine function, sinh(z), specifically around the point z = j*π. The key relation discussed is sinh(j*π) = cos(π)*sinh(0) + j*cosh(0)*sin(π), which simplifies to 0. Participants emphasize the importance of correctly applying the expansion formula sinh(x + jy) = cos(y)*sinh(x) + j*cosh(x)*sin(y) to derive the terms accurately. The conversation highlights the need for clarity in understanding the relationship between the variables involved in the expansion.
  • Understanding of Taylor series expansions
  • Familiarity with hyperbolic functions, specifically sinh and cosh
  • Complex number theory, particularly the use of j (or i) in calculations
  • Basic knowledge of exponential functions and their properties
  • Study the derivation of Taylor series for hyperbolic functions
  • Learn about the properties of complex exponential functions
  • Explore examples of sinh and cosh in complex analysis
  • Investigate the application of Taylor series in solving differential equations
Mathematicians, physics students, and anyone studying complex analysis or hyperbolic functions will benefit from this discussion.
damo03
I am reading through a worked example of the Taylor series expansion of Sinh(z) about z=j*Pi
The example states: sinh(j*Pi)=cos(Pi)*Sinh(0) +jcosh(x)sin(y)
I am unsure of this relation. I understand why the x terms are zero but don't know the relation to expand sinh. Can anyone shed some light on this for me?
Cheers.
I recommend you go back and read the example again. What you write has a constant on the left and a function of y on the right. They cannot be equal. In fact it is not too hard to show that sinh(j\pi)= 0.
Do you mean sinh(j(y+ \pi))?
Cheers.
The example asks: Calculate directly the first two non-zero terms in the Taylor Series expansion of sinh(z) about z=j*\pi
The first step showin is to calculate the two non-zero terms in the Taylor series expansion of sinh(z) about z=j*\pi
f(z)=sinh(z) , Z0=j*\pi
Sinh(j*\pi)
sinh(x+jy)=cos(y)*sinh(x)+jcosh(x)sin(y) (in this case x=0, y=\pi)
It's the above line that I don't understand (how they expand sinh)...
The worked example then goes on to show that sinh(x+jy)=cos(Pi)*sinh(0)+jcosh(0)sin(Pi)
which does indeed =-1*0 + j*1*0 = 0
but that one line expansion of sinh is where i am lost.
You can go from the left side to the right side by "adding and subtracting" the appropriat things but to see what those things should be, it is simplest to work with the right side.
cos(y)sinh(x)+ i cosh(x)sin(y)= \frac{e^{iy}+ e^{-iy}}{2}\frac{e^x- e^{-x}}{2}+ i\frac{e^x+ e^{-x}}{2}\frac{e^{iy}- e^{-iy}}{2i}
The "i" in the numerator and the "i" in the denominator in the second term will cancel. (Sorry about writing "i" instead of "j"- I just can't stop myself!)
The denominators of course will be 4. Multiplying out the numerators,
e^xe^{iy}+ e^{x}e^{iy}- e^{-x}e^{iy}- e^{-x}e^{-iy}
for the first term and
e^xe^{iy}- e^xe^{-iy}+ e^{-x}e^{iy}- e^{-x}e^{-iy}
for the second term.
Now, observe what terms add and what terms cancel.
  • · Replies 16 ·
  • · Replies 18 ·
