Hypersphere Hypervolume Applications?
  • Context: Graduate
  • Thread starter Thread starter Steve13579
    Applications
The discussion centers on the practical applications of calculating the hypervolume of a hypersphere, specifically the formula V=∏2R4/2. Participants highlight its relevance in fields such as thermal physics, where the surface area of a hypersphere is utilized in deriving the multiplicity of an ideal gas. The conversation emphasizes the importance of integration in understanding these concepts, particularly in the context of probability and analysis involving high-dimensional vectors. The integration practice is noted as a key educational aspect for students studying calculus.
  • Understanding of calculus, specifically integration techniques
  • Familiarity with the concept of hyperspheres and their mathematical properties
  • Knowledge of thermal physics and the ideal gas law
  • Basic principles of probability in high-dimensional spaces
  • Research the applications of hyperspheres in statistical mechanics
  • Explore the use of the hypersphere volume formula in machine learning algorithms
  • Study the relationship between hyperspheres and random vector distributions
  • Learn about the derivation of the multiplicity of an ideal gas in thermal physics
Students of calculus, physicists, engineers, and data scientists interested in high-dimensional analysis and its applications in probability and thermal physics.
Steve13579
Hello all,
I was curious on the practical applications of representing a sphere in four dimensions. I recently had to prove that the V=∏2R4/2. I hope I was able to format that correctly. Anyways I couldn't come up with a reason to do some beyond simply proving it for proofs sake. Perhaps modeling the effects of temperature on volume?
Thanks
For 4 dimensions specifically there are certainly applications but probably the main point of the question was just to practice the integration. For n-dimensions in general there are lots of nice reasons to know the volume of a ball/sphere (which is actually the surface of a ball) - for example there are probability/analysis statements about random vectors in high dimension which draw heavily on being able to calculate the volume of various portions of the sphere.
Thanks for taking the time to answer my question. And yes the main point is to do just the integration. I'm taking calculus 3 currently and have already worked it out, took awhile. I was mostly just curious if an engineer would ever use such an equation. I could see the practicality of using higher dimensional functions to calculate probabilities. I may look into that, only a little, for entertainment purposes.
Interestingly, we used the formula for the "surface area" for the hypersphere in thermal physics! It came up when deriving the multiplicity of a ideal gas with fixed amount of energy (related to probability of each microstate of the gas).
First we just assumed there is one particle. So all possible microstates create a surface in the 6 dimensional position-momentum graph (3 component position, 3 component momentum). All possible position states are in a closed shape in the position graph of fixed volume (e.g. a box in the shape of a cube. then all points in the cube are possible position states). But in momentum graph only points on a surface of a sphere (3 dimension in the case of one particle) are allowed because of the total energy constraint. When considering more particles, the sphere in the momentum graph becomes a hypersphere and eventually in the derivation, the "surface area" of this hypersphere is required.
It's a bit strange how such simple object as a n-sphere is also so difficult.
V(n)=2(n+1) div 2 πn div 2 n‼-1 Rn
  • · Replies 47 ·
  • Sticky
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 46 ·
  • · Replies 32 ·
